MY WASHING MACHINE STOP AT RING AND NOT RINGING CLOTHS.
SOURCE: washing machine not spiining
sump hose filter blocked, running out of draining time, when you put it on again it allows more time to drain, remove sump hose and clean out internal filter.
SOURCE: Washing machine wont stop filling up
see if the water coming in is hot or cold by turning the water faucets off and on to see if one fills and the other dont and replace the valve
SOURCE: Washing Machine won't stop filling up
Try resetting your water level control. If that doesn't help then set the water level control to the lowest setting and observe if level exceeds that setting. If so, you may possibly have a faulty water level control, or an obstruction in the air dome or water level control hose. This can be a tricky 1 to diagnose for a novice.
check hose to water level switch, if it has had an out of balance situation it can loosen or detach hose. replace hose firmly back on switch or replace hose if that doesn't work.
SOURCE: washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
