This a cold feed dishwasher that has suddenly showing the letters E14 which we need to know what to do .If we carry on are we going to damage the machine so how do we put it right?
Connect the dishwasher to the HOT water side. Although most dishwashers have a heating element to heat the water, they are normally installed this way to reduce the amount of time the heating element is on. This not only extends the life of the heating element, but also reduces the amount of electricity required to heat the water. Another helpful hint: Before you run the dishwasher, run the hot water tap until the water runs hot. This will fill the dishwasher with water that is already hot instead of the cold water that normally sits in the line after the hot water has not been run for a while. If you have questions, please let me know. I hope this helps you.
though it has a flexible papr handling capabilities you might want to consider the ff:
Stacker Capacity:
100 Sheets
Document Feed:
Automatic or Manual
Document Size:Width: 2.2" - 10.1" Length: 2.8" - 14.3"
Thickness:
Automatic: 0.06 - 0.15mm Manual: 0.06mm - 0.20mm
Feed Capacity:
100 Sheets
all scanner are equipped with double feed prevention, however it still the user responsibility to ensure that you follow manufacturer's advice, to prevent double feeding:
1- do not feed dog eared paper
2- moistured paper or with strong humid
3- concave paper
4- convex paper
