The oven element is broken, how to I replace it?
SOURCE: whirlpool oven model RDE6030A the bottom element
Unplug stove and remove screws holding element to oven cavity. Remove and take to nearest appliance shop and they will match up for you. Not an expensive repair. Hope this helps.
SOURCE: My Defy 621 stove causes the earth leakage to trip
Most likely an element. When the heating wire expands inside the tube it contacts earth and kicks out the earth leakage. Select 'grill' and try the oven. If it does not trip out the lower element is the culprit. Replacement is easy for a reasonably adept handyman - just make sure that the mains are off!
SOURCE: Defy 731 thermofan oven top element not working.
check the element itself visually or by a continuity tester.
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?Which element has gone ?
