Have you replaced all three filters under the cowling?
1. Primary Filter (1st one in the Plastic Bowl)
Reference # 12 in "Prim Fuel" Image
2. Screen on the bottom of the Fuel pump-Inside the VST
Reference # 27 in "VST" image
3. Filter between the VST and the HPDI Pump
Reference # 19 in "VST" Image
Number 2 and 3 get overlooked often, and they are pricy, but they do need to be changed.
If that has been done, the problem most likely is in the fuel pumps
Reference # 24 in the "Prim Fuel" image.
The can be tested by removing them from the powerhead, DO NOT remove the fuel lines, just unbolt them from their mounting leaving the fuel lines attached. Then squeeze the primer bulb until firm. If fuel leaks from the center hole on the fuel pump, Replace them both.
