Sony 32in LCD 720P 16 9 60 HZ Logo
A
Anonymous Posted on Oct 19, 2014
I have a 32in sony triniton flat screen lcd tv that is haooked to dish. I was cleaning the tv remote, not the dish remotr, and I hit something on the remote that lost my sound and picture connection.
I have a 32in sony triniton flat screen lcd tv that is haooked to dish. I was cleaning the tv remote, not the dish remotr, and I hit something on the remote that lost my sound and picture connection. what could I have hit on the rmote and how do I fix it?
Ramesh Gaikwad
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 25, 2014
Ramesh Gaikwad
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
116
Points
I think the source might have changed
5 Related Answers
Anonymous
  • Posted on Jan 31, 2009
SOURCE: Sony Bravia - picture don't fit the screen
I have a Scientific Atlanta cable box w/ Time Warner. I followed the instructions below for the cable box. Somehow it reset my picture and I can now read the ticker at the bottom of the screen and the different picture sizes seem to work properly. Good Luck.
http://newteevee.com/2007/12/15/six-steps-to-get-more-hd-from-your-scientific-atlanta-set-top-box/
Anonymous
  • Posted on Apr 12, 2009
SOURCE: Charter MOXI Remote doesn't work with Sony Bravia 42'' Flat Screen
Hold down the moxi and ok button until the remote flashes twice,then enter 9910. The remote will then blink twice again.Then go back and fourth pressing the mute button and the up arrow key(the one above the ok button)this will go thru all the codes,when your tv finally mutes,press ok that means you found the correct code.Hope this helps
Anonymous
  • 197 Answers
  • Posted on Jun 09, 2009
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Anonymous
  • Posted on Aug 23, 2009
SOURCE: CRACK LCD TV SCREEN
A couple of weeks ago we had the screen broken in our LG LCD TV when one for the kids threw something at the screen. We got a quote to fix it and it was going to cost more to replace the screen than what it would be to buy a brand new TV. We shopped around for a new TV, comparing LCDs and Plasmas. In the end we purchased a new LG Plasma, which had a thin layer of glass over the screen for protection compared to the LCD. We thought this would be much safer with a 4 and 6 year old around the house running amuck. And there seems to be no differfence between the LCD and the Plasma. Hope this help someone's problem.
Anonymous
  • 120 Answers
  • Posted on Oct 16, 2009
SOURCE: Need replacement screen for Sony Flat Screen TV
Replacement screens are to come by. Check E-bay try and find a TV that wont power on. Also www.RNS-Systems.com Has used screens from time to time
Dish Network Remote Codes? Can't seem to get the few I have to work the dish remote
If your remote is a learning remote (has a little black glossy square on the top left side of the remote) you don't need a code, you just need the original remote. Place both remotes on a table, or other flat, sturdy surface, with the original TV remote facing the square on the DISH remote. Make sure both remotes have functioning batteries. On the DISH remote, hold down TV until the button blinks three times, then hold down record (for 5+ seconds) until the TV button lights up and stays on. Then, slowly, for each key you want to use, hit the key on the DISH remote (TV light blinks) then the corresponding key on the original remote (TV light blinks). For example: DISH Volume Up, TV remote Volume Up. When you are done learning all the keys you want to train, hit SAT. The TV light will blink three times, then the SAT light will light up for a moment. Try the DISH remote on your TV functions.
Remote control from Dish tv will not work volume on Coby 32" flat screen
This is not unusual--Dish and other remotes even if program will not have all the functions that may be needed---
I have a Sony 20" triniton and no remote where is
you need to go into on screen menus and scroll to the video settings and adjust there
if there is no button for menu on front then you should write sony for a replacement remote as most aftermarket replacement remotes dont do the setting functions you are looking for
good luck - hope this helped you
I have Dish Network and remote #1 and 2...the TV for Remote #2 has now changed but the remote will not work...I replaced it with an Olevia Flat Screen (used one) 32in LCDHDTV Model 432-S12 but cannot...
If this hasn't been resolved, I do have some steps that will help you out. The link below will walk you through a power scan, which will program the remote to the tv. At that point, you will be able to change the channels on the tv with the remote.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
1helpful
DIRECT TV REMOTE WON"T WORK WITH MY RCA 32in LCD
if you want to use a single remote, try buying a learning remote
1helpful
Need code for 32in.olivia tv
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, TiVo’s, DVD, Blu-Ray or even HD- DVD players. The learning remote is available at 866-965-3842
Dish Network Remote Codes 506 or 127
could try Dish Network..Remote Codes 506 or 127
Satellite TV Systems Dish Network Remote Codes 506 or 127
15helpful
6answers
Envision remote codes
Try
10813
11365
10032
10039
10019
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
