I DID TRIED TO TURN THE TV OFF AND ON AGAIN,I DID TRY THE AUTO SEACH BUT STILL SHOWING THE WORD (NOT PROGRAMMED) AND NOW I DONT KNOW WHAT TO DO OR HOW SHOULD I GET THE PROGRAMMING STARTE ON THE TV USING THE REMOTE?
Look up serivce codes for the TV they use the 4 colour buttons to allow to service mode
so once you get back to service mode with a good remote
then set it to default factory if you can
or atleast then you can cancel out any changes etc
to get back in
look for the service manual for its modek
and work from there
SOURCE: Using the guide button on the remote i can only
. Hello, I need a few more details to be successful and focus on the problem, I understand you tried the options for manual and automatic scanning. If so did you see during operation the scanning movement on the screen? If so, have you seen the stations in the background while scanning, and the phenomenon was that they did not stop on the station you selected?
SOURCE: 37lg30 will not turn on
I'd check out the IR board on your tv. If you have electronics experience open up th etv find the IR board - trace it back to the AV board make sure all connections are plugged in good then if that doesnt work I'd replace the IR board first. That would be the cheapest part to replace. Also it could be the IR on the remote - but if the codes you used to program the programmable remote are known good for your model i'd look at the tv first.
thanks,
michael
