If flickering occurs to DLP projectors; due to two reasons. Fault with its lamp or internal power supply regulator circuit. Before replacing the lamp, you should make sure about its power supply section circuit [SMPS] works properly, and supplies exact voltages for its lamp inverter. Somewhat skilled work, and will be best to contact any service technician. http://electronicshelponline.blogspot.com/
SOURCE: hitachi projector cp - s210
hi there,
I have just done the exact same thing today. Press menu button on projector. Scroll (navigate) to the mirror option. This give you the options to mirror image left to right or up and down.
This should fix any of your problems.
Cheers
Luke
SOURCE: Vertical lines on my Hitachi CP-S225 projector
just changed bulbs on my projector a Hitachi cp-s225 wt and i still see a lot of blue and there are lines o green running down the left side
SOURCE: Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
