Acu-Rite Acurite Wireless Weather Thermometer 604 Logo
A
Anonymous Posted on Oct 19, 2014
How do I set the time of day and date on the acurite 1099RX
How to change the day time and date on the acurite 1031 rx?
https://acu-rite.com/support/product-literature/
1helpful
I need help to reset acurite 020010 rx
Battery compartment contains reset button. Press. Will need to re-enter time and date.
https://www.acurite.com/kbase/weather-stations/02031RM_Weather_Station.html
I have an acurite model 13020CCDI I just would like to know how to set up time and year 'I can do the other things
page 6 and 7
Intelli-Time
clock and calendar are pre-programmed to the correct time and
date, and update automatically for Daylight Saving Time. All you need to do is
select your time zone using the "ZONE" button
https://www.acurite.com/media/manuals/13020-13026-instructions.pdf
After changing batteries clock won't reset help
Set the Time & Date
The clock and calendar are utilized to time stamp history records and other data, so it is important to set the time and date soon after you power on the display unit.
Set the Time
1. Press the "up arrow" or "down arrow" buttons until "SET CLOCK?" is displayed on the Selectable Category part of the display unit.
2. Press the "SET" button to set the clock.
3. Press the "up arrow" or "down arrow" to adjust the hour.
Note the "AM" and "PM" indicators.
4. Press the "SET" button to confirm hour
selection.
5. Press the "up arrow" or "down arrow" to adjust minutes.
6. Press the "SET" button to confirm minute
selection.
The clock is now set.
https://www.acurite.com/media/manuals/01010W-instructions.pdf
BACK OF DISPLAY UNIT
1. A-B-C Switch
ID code that must match 5-in-1 sensor’s A-B-C switch to ensure units synchronize.
2answers
Model 1099rx not working,even after I replaced all batteries
If this is for the AcuRite weather station, please contact customer support at: http://www.acurite.com/support
1helpful
2answers
How do I change from Fahrenheit to celcius? Model # 00621cadia2
You can download the manual here http://www.acurite.com/kbase/00621_Weather_Station.html
Set the Time, Date & Units Press the "SET" button, located on the back of the display unit, to enter SET MODE. Once in set mode, the preference you are currently setting will blink on the display.
To adjust the currently selected (flashing) item, press and release the "up" or "down" buttons (press and HOLD to fast adjust).
To save your adjustments, press and release the "SET" button again to adjust the next preference. The preference set order is as follows:
TIME ZONE ( PST MST CST EST AST HAST AKST) DST (Daylight Saving Time ON or OFF)*
CLOCK HOUR
CLOCK MINUTE
CALENDAR MONTH
CALENDAR DATE
CALENDAR YEAR
TEMPERATURE SCALE ( ?F or ?C) BAROMETRIC PRESSURE SCALE (inHg or hPa)
*If you live in an area that observes DST, DST should be set to ON, even if it is not currently Daylight Saving Time.
You will automatically exit SET MODE if no buttons are pressed for 30 seconds. Enter setup mode at any time by pressing the "SET" button.
How to reset my Acurite 1099rx after replacing battery
http://www.acurite.com/advancedsearch/result/?q=1099RX
There is no reset button, installing new batteries causes the sensor to reset itself.
Try removing and re-installing the batteries.
Good luck,
Steve
ACU RITE Wireless Thermometer Model L5C0668TX cant set the date
I have misplaced the user manual for the
Acurite L5C0668TXACU RITE Wireless Thermometer Model L5C0668TX. Where can I get another?
Acu-Rite Wireless Thermometer indoor/outdoor, the only identifying number I can find is inside where the batteries go, a sticker says: 0417. Question: 1) On the indoor piece, I can set the clock to the...
Before attempting to set the time, let the outdoor transmitter sync with the indoor receiver. Once that's done, you'll be able to successfully set and retain the date and time.
Top Acu-Rite Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
