Why does it click on for a few seconds and hums slightly but then clicks back off without turning compressor on?
That is what is sounds like but let's check. An overload relay will fail due to wear, a short or a bad compressor will knock it out. There is a rare occasion you may purchased a bad overload relay, but that is rare. The rattling of the overload relay is a good indicator it is bad, however it does not have to rattle to be bad - inspect for burn marks as well.
The clicking sound is the overload relay trying to start the compressor. There will be a pause and then click trying to start the compressor again.
Remove the overload relay component and expose the three pins on the compressor. Using a multi- meter, measure the Ohms across the three pins. You will get one high Ohm reading and two lower Ohm readings. If the two lower readings add up to the higher reading the compressor is good. Make sure the green ground wire is securely grounded. It could nock out the overload. Check for loose connections. Replacing a compressor is a major repair. The cost will exceed the purchase price. Rule of thumb; "If the cost of the repair is 1/3 or more of the purchase price of the unit, Buy new".
As a retired Sears service technician, we considered these units
as throw-a-ways due to the high cost of repair. If you had a service contract we would replace the unit rather than repair it
SOURCE: Kenmore (253.51399104)side by side making buzzing/humming noise
It will rattle slightly, this is normal. The ones that are burned out will sound like they have gravel in them, you can defininely tell something is wrong.
The problem with diagnosing Kenmore fridges with this problem is that there are different manufacturers. Yours is built by Frigidaire and probably has a Tecumseh compressor. We find more failed compressors with the Tecumsehs than we do with the models that have Embraco compressors. The models with Embraco's generally have more relay failures.
You should not hear the buzz/hum at startup. You will need to replace the compressor, which will be replaced at no charge to you if it is less than 5 yrs old.
If it is older than 5 yrs, you can have it replaced, but it will be almost as expensive as a new fridge. You can buy an aftermarket start device called a 3-in-1. This has a start capacitor built in to give it a little more boost on start up. I don't recommend using them unless it is a short term fix until the compressor can be replaced or if it is out of warranty and there is nothing to lose anyway.
Thanks/Mike
SOURCE: refridge hums then you hear
it sounds like
a bad:
SOURCE: clicking near compressor but doesnt
since your mini fridge is under warranty, have a technician come and take a look at it. i would say it's the damper.
SOURCE: Mini Fridge not working MCBR445
Compressor is in a locked up/ no start condition. the overload cools enough to reset and tries to start it again and kicks out on amp draw, then the whole cycle starts over again.
Eric
SOURCE: Refrigerator stopped cooling.
My LG mini fridge stopped cooling. The light is on and every now and then i hear a click. The motor in the back is hot and i cleared away all the dust. Any suggestions would be very helpful?
HSA04WNCBB HAIER 1.8CU. MINI REFRIGERATOR
By clicking on the part numbers in blue on the left should take you to where you may find those parts. If you have any questions please let me know, Thanks, Sea Breeze
If helpful please rate this solution...Thanks Again
