KitchenAid Architect ® II KEBS208S Electric Double Oven Logo
A
Anonymous Posted on Oct 18, 2014
Error message F6E6.What does this mean?
Not sure on the exact model number. My book has several listed KEBS109,207,209,101,206. I'm getting error message F6E6. The top element turns on even if you only are cooking with the bottom oven.
Nater13
Level 3:
Master:
  • KitchenAid Master 610 Answers
  • Posted on Aug 30, 2016
Nater13
KitchenAid Master
Level 3:
Master:
Answers
610
Questions
0
Helped
242255
Points
2229
Although fault code "F6E6" most often indicates a communication failure between the User Interface and Appliance Manager board (Service Pointer W10538518), it could also indicate an incorrect electrical connection at the customer's home junction box. Sounds like you have some wires crossed!
5 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Dec 29, 2007
SOURCE: General Electric Double oven wall unit
id say something different like a thermal fuze or relay
Anonymous
  • 1314 Answers
  • Posted on Mar 30, 2008
SOURCE: Kitchenaid Convection oven
F5
E0
E1
DOOR AND LATCH SWITCH DO NOT AGREE
DOOR LATCH NOT OPERATING.
PROCEDURE: Before proceeding, press OFF, OFF, START to enter
the Diagnostic mode and verify the error codes.
TO VERIFY DOOR SWITCH:
A. While in diagnostics, open the oven door. The second digit on the clock display
should toggle between “1” and “0” as the door opens and closes. When door is
closed display should show “1”, when the door is open display should show “0”.
If the second digit on the clock display did not toggle, go to step B.
If the digit did not toggle after replacing the door switch, go to step D.
If the digit did not toggle after replacing the door switch harness, go to step F.
B. Unplug oven or disconnect power.
C. Replace door switch. (If door switch is integral to the door latch motor
assembly, replace the entire door/latch motor assembly). Go to step H.
D. Unplug oven or disconnect power.
E. Check the integrity of the harness wires and connections between the
appliance manager and the door/latch assembly. Ensure there are no shorted
or pinched wires.
If the wiring harness is pinched or damaged, replace the door switch harness.
Go to step H.
If wiring harness is good, go to step H.
F. Unplug oven or disconnect power.
G. Replace appliance manager. Go to step H.
H. Replace all parts and panels before operating.
I. Plug in oven or reconnect power.
J. Press OFF, OFF, START to reenter the Diagnostic mode and complete checks.
Repeat step A.try this lighting may have knocked either the door switch or latch motor out
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Mar 21, 2010
SOURCE: error message on panel of my kitchenaid oven
shorted keypad
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Anonymous
  • 15935 Answers
  • Posted on Oct 01, 2010
SOURCE: E1 and f5 error/Door locked
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
espressonist
espressonist
  • 1711 Answers
  • Posted on May 05, 2011
SOURCE: I get the error code FSE1, lock won't engage
F5 - E1 Self clean latch will not lock
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
3answers
What does Miele Oven error 235 mean?
Model number is ..................................
Apr 02, 2023 • Miele Ovens
2answers
Hi. How can I fix error F6E6?
We bought this oven too for our newly renovated home, we used it for six days before it failed due to an electronic error (F6E6: Appliance Manager 1 Board Communication). After a failed warranty repair attempt and multiple phone calls/complaints we eventually got Whirlpool to agree to give us a new oven. We had to wait six MONTHS for this new oven to arrive due to it being out of manufacture. Our second oven arrived and worked for 8 weeks until this weekend, it failed again with an F6E6 error! Now to try and get it repaired replaced!
There is obviously something wrong with the electronic design or poor-quality components are being used. We strongly recommend you do not buy this oven.
We bought a matching combi oven from the same range which means we have to stick with this oven or we will end up with ovens that don't match in a brand new kitchen!
My kitchen aid double oven has an error code f6e6 contact am1
Possible Solutions
Reset power to the product:
There may be a problem with the Oven Appliance Manger Control or the associated wiring.
  • Power unit down by turning off the circuit breaker(s) for one (1) minute.
  • Power unit up by turning on the circuit breaker(s).
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify oven operation.
Still need help? Call or schedule service.
1helpful
My mbleoven had a E2-F2 code what is the oro
The F2 class of error messages means that the keypad and the control unit aren't communicating properly. First turn off the circuit breaker to the range for a minute. Check if the error recurs after you clear the PF message. If the error recurs, turn off the power again. You need to check the wiring between the keypad and the control unit. Make sure that all of the wire harness connections are fully seated and all the wires are undamaged. It's not uncommon for one wire to get broken so check the continuity.
If that doesn't help, you probably need a new keypad. If you add a comment with the model number of your oven, I may be able to point you to a supplier.
I hope this helps.
Why won't my oven let me set the temperature after a power failure?
Good Morning Annette,
I see that you are having trouble with setting the temperature of your oven on your range, model# FGB24S5A, after a power failure. I also see that you have reset your appliance by unplugging it and are receiving an error message of SAG or 5AB. I have looked into the model number that you have listed and it shows as a wall oven. I also do not show either of those error codes you have shown. If you can please get me the model number off your range, so I can better assist. The model number will either be right inside the oven on the back of the door or it may be located inside the bottom drawer. Looking forward to hearing from you.
WP
F1 code
Most F1 error codes refer to a communication error in the main control board/ clock on some there are reset overload switches that if tripped show as a push button that is pushed outward that you can reset. This also mainly depends on which type of oven that you do have and you would have to provide the make and the model number of the unit in order for me to give you an exact solution to your f1 error instead of a generalized one. Sometimes also you can turn off the power at your electrical breaker for 7 minutes which this causes the control to reset in some. Most of the time in most models though the F1 refers to having to replace the electronic control module (ECM. If you have any further questions or wish for me to look up the exact error for your unit message me back your make and model number and I will give further diagnosis on your unit. Thank you again
Rick
Nov 26, 2011 • Ovens
This message is displayed on my oven: EO - F2 - What does it mean?
E0 F2 fault code usually indicates a shorted touchpad on the oven control. Firs disconnect power to the range for 30 seconds and restore it. This will cause the electronic range control to reset and sometimes will clean errors.
If the error returns the touchpad on the control will have to be replaced. Some ranges have the touchpad made on the control and the oven control has to be replaced.
Open the drawer under the oven and look on the frame of the range around the opening the drawer slides into for a model number tag. Get the model number of the range and go to searspartsdirect and you can see a parts diagram and list for your range.
Hope this helps.
Sep 21, 2011 • Ovens
What does an error message "F0" mean for kenmore model 911.41185991?
for a maytag the F0 code means a function key is stuck, and recommends changing out the touch pad, or touch pad and oven control assembly if one unit. google your model number for error codes.
Jun 21, 2010 • Ovens
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
F1 error message on kenmore gas range
The F1 usually means a problem with the touchpanel. It is also related to the F7 problem. I have developed a fix which may solve you problem. Please go to the following link for my fix.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my fix with over two thousand unhappy GE customers. Most report success. Please let me know if this works for you too. I am making a statistical study of this problem.
Regards,
Powerman
[email protected]
Top KitchenAid Ovens Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
