Front loader, it will start to barely fill with water and stop. Same with any drain or rinse cycle. The timer keeps going, but it will not move past the first 30 seconds of any cycle.
Washer stopped working, similar to your experience, water would start and stop after a few seconds and not progress. It displayed E5E error when prompted for code. I opened up the back of the machine and noticed that a connector was not connected to the control board, i removed the control board to get a better view of where it belonged, and slid the connector over the control board, closed up the machine and it's back in business.
Hey friend, thanks for your inquiry!
I see your Frigidaire washer is displaying an error code "e5e". However, it appears "e5e" is an invalid error code. Let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes.
If resetting the power does not correct the issue, could you please inform me of the new error code or if your dishwasher continues to display "e5e" you may want to seek assistance from a professional for proper repairs. -Matt
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
SOURCE: frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
SOURCE: Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
SOURCE: Washing Machine starts, squirts water, then stops.
E5E IS FOR Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
SOURCE: stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Hello barnessursula - Typically error code E5E indicates that there is a communication problem. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the wiring between the main control board and the speed control board. Depending on the diagnoses and if the wiring is bad, it has to be corrected. However, if the wiring is good the main control board will need to be replace or if the problem is not corrected, the speed control board will need replacing.
Hello Ivan Kelly - Typically error code E5E indicates that there is a communication problem. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the wiring between the main control board and the speed control board. If the wiring is bad, it has to be corrected. However if the wiring is good the main control board will need to be replace or if the problem is not corrected, the speed control board will need replacing.
