SOURCE: one key recovery is deleted
if you mean to restore the one key recovery
copy the one key recovery partition from other laptop with Hiren all in one Cd
http://www.hiren.info/pages/bootcd
inside the cd you can found norton ghost
run it
then choose the operation
choose partition
choose to image
save to any partition
then proceed the image creation
then copy the file *.gho
to your hard disk drive
then make a partition that at same size with the one click recovery partition
then run again norton ghost at hiren CD like before
choose partition
choose from image
designate where the .gho file is located
then follow the prompt
------done------
SOURCE: IdeaPad S10e Netbook: CANT OPEN LENOVO ONE KEY RECOVERY UPON START...
Make sure you did it correctly. Computer should be OFF when doing the one key recovery. Turn off the computer then press the small button right beside the power button. Your computer should automatically turned on and you will go straight to one key recovery software. If this will not happen, then the one key recovery is destroyed. We need to re-image your Harddrive to have that one key recovery software back to you computer. You may call Lenovo technical support department for further assistance on how you are going to send your laptop to our depot department.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: i removed service partition during
This is true. The recovery partition would have recovered the original configuration only. Since you installed Win7, you don't need the partition anyway.
You may have hardware issues or the window files are corrupted, if you made a backup recovery on a DVD disc try it know, if that fails the hard drive needs to be assessed for replacement.
