E-Machines eMachines Desktop PC Logo
A
Anonymous Posted on Oct 18, 2014
I have emachine model el1358g-51w. When turning pc on the monitor shuts down. I need to unplug and replug the power cable to monitor and it turns on again. I've tried replacing the power ca
I have emachine model el1358g-51w. When turning pc on the monitor shuts down. I need to unplug and replug the power cable to monitor and it turns on again. I've tried replacing the power cable and cleaning the computer tower of dust, all plug in cords seem good in the pc. Any suggestions what could be the problem?
Electroboy
Level 3:
  • E-Machines Master 1,888 Answers
  • Posted on Oct 21, 2014
Electroboy
E-Machines Master
Level 3:
Answers
1888
Questions
Helped
674726
Points
3733
Hi. If you are using the on board graphics (the blue connector for the monitor), it sounds like a video driver issue. Try updating the graphics driver. I think that model has geforce graphics so there should be a small NVIDIA icon (hover the pointer over the icons to find nvidia one. Don't forget to click the small triangle next to the icons to show hidden ones) down by the time on your desktop. In there, you should find an update option.
innominato
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Oct 19, 2014
innominato
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
908
Points
21
The model number you gave did not include a monitor. Can you give details about the monitor itself like manufacturer and model number? Is the monitor an older style big and deep or an LCD panel style? The symptom you describe seems typical of some kind of electrical protection disconnecting power to the monitor same way as a circuit breaker in your house.
5 Related Answers
Anonymous
  • 15 Answers
  • Posted on Nov 08, 2007
SOURCE: Emachine desktop
I understand that your cpu is not turning on and the repairer confirmed that it is the issue with the mother board. I suggest you to please check the smps fan spinning or not. If its spinning then then the issue could be with the mother board. If not try changing the power cables.
Next check whether your cd rom light is glowing. Even if there is an issue with the mother board, as the power is supplied by the smps the light  should glow if the light is not glowing its clear that something must be wrong with smps.
Please provide us the result of the above steps so that I could assist you further.
Anonymous
  • 236 Answers
  • Posted on Mar 26, 2008
SOURCE: emachines wont boot
Could be a cmos battery, try changing it. Sometimes that works.
Anonymous
  • 749 Answers
  • Posted on Mar 28, 2009
SOURCE: tower won't turn on
hi try to put the monitor lead in the tower, the leads are both the same, the fuse might be out in the tower lead.
info2u
Nouveau IT, LLC
  • 596 Answers
  • Posted on Jul 21, 2009
SOURCE: how to connect emachine flat monitor to my computer?
It sounds as if you are missing the power cord for the monitor. If the cord did not come with your monitor/PC, you can pick one up at any Radio Shack or electronics store. If you could forward me your eMachine model number as well as the monitor model number, I will see if I can better solve this for you without you having to spend anymore money.
Best Regards,
Franklin, C2Solutions
Robert Bivins
  • 192 Answers
  • Posted on Jul 28, 2009
SOURCE: eMachines t3626 shuts down at random
You may be dealing with bad or overheating with your processor or memory. If possible, try swapping out your memory chips to see if that does the trick. If not, you will have to try swapping out the processor (much less likely you'll be able to swing that).
How can I restore emachines EL1358G-51W?
If you can boot into Windows 8
  1. Power on your computer.
  2. Press the Windows and C key to begin a search.
  3. Type recovery and click eMachines Recovery Management.
  4. Click on Restore Factory Settings, at the Restore tab from the left menu.
  5. Click Next.
  6. Click Fully clean the drive option.
  7. Click Reset.
More items...
eMachines Recovery Disk - Guide for Windows XP, Vista, 7, 8
How can restore emachines EL1358G 51W Google Search
Open case how to el1358g
9xejsknreuu9+p8eghor1yaijqaaaabjru5erkjggg==The Two Thumb Screws above and below.
Can video card be upgraded in emachine el1358g-51w
yes you can upgrade the graphics card, you have integrated graphics but you can purchase a PCI-E graphics card and bypass the on board graphics but keep in mind you'll have to buy a "low profile" graphics card as there's not much room in your case and a full size card will not fit.
Keeps crashing before it gets completely on
Yes, I use them for a year, and then they sell them.
Is there a problem?
OH, C'MON I'M JUST KIDDING!
1) Is the computer dirty inside?
The two major issues with desktop computer failure, is the computer is dirty inside; and Power Supply failure.
Post back in a Comment. We'll start here.
Be prepared for a 'Windy' tech. You may do so much reading, you'll feel like you are back in school.
(I explain in detail, as if you know absolutely nothing about your computer. Just the way I ride )
Regards,
joecoolvette
1helpful
Replace power supply
Be sure to look on back of tower to see what power you need. The power plug needs to be 115v or 125v on most. Be sure your cord is the same voltage.
2helpful
2answers
Emachine shut down
No, it's just the USB ports that are still being powered.
Totally normal in most new computers. Same thing with the PS2 ports.
There are jumpers on the motherboard that can change this if you really want. It's designed like that to keep things like you have powered for when you do turn it on and need them.
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
