Belt is torn how do I replace it?
First, go to a vacuum store ("sewing and vacuum" shop in some places) and purchase the correct belt. You unlock the rug plate by unhooking two latches on the rear of the nozzle. The rug plate is the steel item which rubs on the carpet and locks the brush roll in place. Just look on the bottom and you will see two steel levers which you need to move. You then lift out the brush roll: pay attention while you do this to see how it comes out, as that knowledge will help when it is time to put it back in. You then place the new belt over the brush roll and then replace the brush roll. On my Gsix, one of the plastic brush roll ends is larger than the other. The roll will only fit in one way, so flip it around if you can't get it to smoothly slide in place. Maybe it is the same on your G4.
SOURCE: I have torn my file
Kirby models are all very similar. The only manual I've been able to locate is for the G6. You can download or print it from the below link.
http://ubermanuals.com/search/contentsearch/kirby
Or check the belt change video at the following site. I recommend making this site a favorite for easy access to these videos.
http://www.kirby.com/Portals/0/videos.html
SOURCE: How do I change the belt?
Here's a link to my free online guide. Hope it helps...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Marci
Here is my online guide for belt replacement,,,,HOPE IT HELPS!
Marci
