Error 20 is an error code in Xerox laser printers which indicates interior hardware damage.
This printer problem usually occurs after the installation of new parts or supplies. It means the installation was not done correctly or a part is already worn out and needs replacing.
Here's what to do when Error 20 Code appears on Xerox Phaser 6500. When this error code appears, one of the first things to check is the toner level.
It might be too low to print with the consistency that it requires replacement. If you have replaced the toner cartridge and the error persists, reinstall the cartridge.
Turn off the printer wait for a few seconds before turning it back on.
Avail prompt online help by experts just at dialing Xerox Printer Support Phone Number +1 888 597 3962 which is available 24×7 hours. We are independent customer service providers, and having a team of experienced and dedicated tech support technicians, who are always ready for assistance. Our proficient technicians have provided the most appropriate solution and tremendous guidance e to customer for resolving their Epson Printer technical issues. Hence, call us the at toll-free number and get the extensive support, easy guidance and 100% guaranteed solutions with our professional help to resolve Epson printer issues within a defined timeline.
Error: 52.XX.00 Error To continue turn off then on
Error Description: Laser/scanner error ? XX = 00 laser/scanner motor startup error ? XX = 20 Laser/scanner rotation error
check your printer scanner assy. need technician support.
Hi, F20 indicates a water inlet problem (no water or insufficient water supply) in your washer. To resolve this issue check your washer inlets, maybe the water valves are off or you don't have enough water pressure. Thank you!!
