Please see below. I believe that you have set the tuning to LOCK, hence the KEY symbol. I have done the same thing with other radios. I bet you never forget this!
Manual Tuning with Rotary Dial You can select a higher or lower frequency by turning ROTARY TUNING. Set FAST/FINE/LOCK to select the rotary tuning increments or to lock the ROTARY TUNING dial. The following table shows the tuning increments for the FAST and FINE settings. '------'------'-------'------'-------' ' ' FM ' LW ' MW ' SW ' '------'------'-------'------'-------' ' FAST ' 0.1 ' 9 kHz ' 9/10 ' 0.005 ' ' ' MHz ' ' kHz ' MHz ' '------'------'-------'------'-------' ' FINE ' 0.05 ' 1 kHz ' 1 kHz' 0.001 ' ' ' MHz ' ' ' MHz ' '------'------'-------'------'-------' To lock the ROTARY TUNING dial, set FAST/FINE/LOCK to lock. This keeps you from changing the frequency if you accidentally touch the dial. NOTE: This locks only the ROTARY TUNING dial.
The DEH-P7900BT is almost identical to the DEH-P85BT sold in Europe.
This
is a US model and will tune most AM/FM stations in the UK/Europe. The
FM broadcast band is 87.8 to 108.0 MHz. so it will not pick up any FM
stations outside this range. Also, the tuning is in odd increments
(such as 96.1, 96.3, 96.5, etc.) so some stations with even frequencies
will be slightly distorted, depending on the power of the signal the
station generates.
I found this bit of info for you but ill keep looking and let you know what i find out. Also have you tried it in europe to see if it does work or not let me know ok
What is there to fix? You have now access to a larger interval of tunable frequencies. There are two or three selectable FM ranges. In Japan you can tune between 76 MHz and 108 Mhz. In North America the range is between 87 Mhz and 108 Mhz. There is 3rd one called School Band but I do not recall the limiting values.
Take the cover off and look at the cable that connects the tuner to the main board. Make sure it is connected straight and tight. Make sure all screws in the back are tight, just in case it is a grounding issue. Iff all checks out and you still have issues, replace your tuner.
For the Grant 40 channel CB there are 40 frequencies I will list below.
When you refer to the upper and lower channels for this raidio you must mean USB (Upper Side Band) and LSB (lower side band).
This is called single side band modulation which is to say the the carrier is removed from the upper or lower sideband depending on which your pick and the signal goes farther on less power.
So the upper and lower side bands are the same frequency just upper side band or lower sideband.
26.965 MHz21.27.215 MHz
26.975 MHz22.27.225 MHz
26.985 MHz23.27.255 MHz
27.005 MHz24.27.235 MHz
27.015 MHz25.27.245 MHz
27.025 MHz26.27.265 MHz
27.035 MHz27.27.275 MHz
27.055 MHz28.27.285 MHz
27.065 MHz29.27.295 MHz
27.075 MHz30.27.305 MHz
27.085 MHz31.27.315 MHz
27.105 MHz32.27.325 MHz
27.115 MHz33.27.335 MHz
27.125 MHz34.27.345 MHz
27.135 MHz35.27.355 MHz
27.155 MHz36.27.365 MHz
27.165 MHz37.27.375 MHz
27.175 MHz38.27.385 MHz
27.185 MHz39.27.395 MHz
27.205 MHz 40. 27.405 MHz.
If you have any comment please feel free to leave them here.
Storing the strongest broadcast frequencies BSM (best stations memory) lets you automatically store the six strongest broadcast frequencies. 1 Use MULTI-CONTROL to select BSM in the function menu. 2 Press MULTI-CONTROL to turn BSM on. The six strongest broadcast frequencies are stored in the order of their signal strength. # To cancel, press MULTI-CONTROL again. Tuning in strong signals Local seek tuning lets you tune in only those radio stations with sufficiently strong signals for good reception. % Press LOCAL repeatedly to select the desired setting. FM: OFF—LEVEL1—LEVEL2—LEVEL3— LEVEL4 MW/LW: OFF—LEVEL1—LEVEL2 The LEVEL4 setting allows reception of only the strongest stations, while lower settings let you receive progressively weaker stations.
You can also perform this operation in the menu that appears by using MULTI-CONTROL. Selecting alternative frequencies When the tuner cannot get a good reception, the unit automatically searches for a different station in the same network. 1 Use MULTI-CONTROL to select AF in the function menu. 2 Press MULTI-CONTROL to turn AF on. # To turn off, press MULTI-CONTROL again.
! Only RDS stations are tuned in during seek tuning or BSM when AF is on. ! When you recall a preset station, the tuner may update the preset station with a new frequency from the station’s AF list. No preset number appears on the display if the RDS data for the station received differs from that of the originally stored station. ! During AF search, sound may be temporarily interrupted. ! AF can be turned on or off independently for each FM band.
The short answer is yes. The method is to set the TV to receive either channel 3 or 4. The converter will receive the digital broadcasts and "re-broadcast" them on either 3 or 4 analog for the TV to receive.
According to the manual the Pro 94 should cover that frequency.
Please note, certain frequencies are blocked in some countries. I see no reason why 217.031 should fall into this category although the closest may be 217.030 which should be close enough
Take a look at the manual >HERE< which should help you to program your scanner.
