UPG 12V 12Ah Electra Scoot-N-Go 88615 Electric Scooter Electric Bike Battery - UB12120ALT132 Logo
v
victor contreras Posted on Oct 18, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Okay, I'm working on a scooter for my nephew that originally came with (2) 12 volt 12Ah batteries minus the charger. and I know I need to replace them with (2) batteries of the same 12 volts and lets
I need to replace (2) 12 volt, 12Ah batteries along with the appropriate charger for a scoot n' go electric scooter and I'm aware that the voltage needs to be exact but what amount of amps should the 24 volt charger be pushing in order to make it as good as new?
Richard416282
Level 2:
New Friend:
  • Expert 46 Answers
  • Posted on Feb 16, 2015
 Richard416282
Expert
Level 2:
New Friend:
Answers
46
Questions
0
Helped
41231
Points
119
The Charger has to have 3 "Special" functions that an "ordinary" Car Battery Charger does not have.
A) OVER-Charging Protection : This is so you do not over charge the cells, and cause the hydrogen to release from the acid..... This could cause an explosion and battery acid all over the place if the case cracked and the contents of the cells leaked onto the floor.
B) Charge Monitoring - As the cell voltages go up, the current going into the battery slows down so that the amount of charge being put into the battery is equal to the losses from the battery on its own (Trickle Charge). When the Battery is in a discharged state the overall voltage may be 10 volts. (it should be only discharged to 85-90 % once in 20 cycles (deep discharge), the rest of the time it should only be discharged 75%.
So you tell me the Capacity of the batteries are 12 Ah. Lets assume you use up 75% of the 12 AH, this suggests that 9 ampere hours have been used up. To replenish that energy you need to put back in 9 ampere hours, plus 10-15% for losses in translation.
For a 24v system , this means that the Amount of current has to be limited to 2-4 amps at 28 volts. The Batteries need to be hooked up for 2-3 hours only, then checked for their cell voltage. once the cell voltage is at 1.25 volts per cell (check with the Battery manufacturer for confirmation) you can stop charging the batteries. they will be full
C) Over Current and Cell matching - The Charger has to be designed to pump out only so much current that the battery can handle (the Charge Rate). Typically for GEL-type cells, the Charge rate is 0.5 (this is 1/2 of the 9AH rating,) so the MAX that can be pumped in is 4.5 amps. Check with the Battery manufacturer to be sure. (see above about hydrogen)
Once you get the specifications for the battery(s) you can get the correct charger to match.
Marco De La Fuente Fernandini
Level 2:
Habit-Forming:
  • Expert 160 Answers
  • Posted on Nov 05, 2014
Expert
Level 2:
Habit-Forming:
Answers
160
Questions
Helped
65557
Points
361
Not exact, to charge apropiate needs 10% more than nominal voltage. if not, will not charge the batteries.
And the charger its very important because you can over charge the battery.An example,if you have a 12 Amps Batteries each one if you put it in series will be 24 Volts.at parallel conection will be 12 volts but the double of Amps.
At serial connection will be 12 Volts the amps will be the same but the volts will be 24.
The charger at 12 Volts must be 13.8-14.5 DC Volts and divide the Amps in Hours.
The charger at 24 Volts must be 26-28 Volts. to charge well.
The charger for 12 amps batt example must charge 2 amps per hour at 6 hours = 12 Amps.(2 Amps Charger by 6 Hours Charging= 12 Amps.(Fully Charged.
3 Amperes Charger needs 4 Hours to charge 12 amps Batt.
5 Amperes Charger needs 2 Hours charging an a quarter
All of this is at DC Current.
Luck.
My scooter is AUTOGO 550 vision 8.5amp NIMH as per receipt. 1. CAN this battery BE REPLACED FOR 2 SLA BATTERIES? 2. WHAT ARE THE CHARGER SPECIFICATIONS I REQUIRED? 3. ANy recommendations or caution?
I also have the same problem. Want to replace the lithium battery with lead acid but cannot figure out how to wire them up. Just wondering how you managed iy yourself
1helpful
When I turn my luggie scooter on the light blinkd 3 times. I just bought a used lithium battery and charger (and adaptor for sla battey conversion to lithium). I read that 3 blinks means voltage is too...
hi, okay the charger is 29.5v charger so the batteries will go as high as 32 voltage,
Was the battery originally come supplied with a lithium battery ? because you mention the SLA adaptor ?
If you have the luggie that came with the Lead acid battery , the voltage would be lower and I think that 's the problem, fitting a lithium battery on a (controller ) configured scooter for a Lead acid means a lower voltage hence the error message.
looking at a max of 30 volts Lead Acid,
29.5 (top charge ) 36v Lithium battery.
Regards
Rob
1helpful
2answers
My gogo elite traveller wont chrage. The charging light isnt on when i plug the scooter in.
Sounds your batteries are to low in voltage for the charger to recognize. Also check the fuse on the battery box, normally a red one 10amps.
2answers
Why does my 150 cc SUNL scooter not hold a charge? New battery is no different than original. It is a 2008 with 26 miles on it
Doesn´t matter the miles runned.
The battery is too old. chemicals inside are not capable to hold Current(Amperes).
Yo must change the Battery by a New one with the same parameters. (Volts,Amps, Size.)
2008 from now it´s too much time for a Battery, even unused.
On my charger both, lights flash green as i try to recharge, but it only recharges a little.
Hi , use the scooter for about 10 minutes, okay now plug in the charger, do any of the lights go red or orange to indicate it's charging, if not , remember one green light is to indicate it's turned on...
1. Check the voltage can be seen at the charger socket, (mulitmeter required here volt DC setting looking at the two outside holes)
2. Is it not possible to try another charger ? as long as it the same fitting ...
3. Is there a fuse for the charging line?.
4. If all fails then it seems the batteries need be replaced.
Regards
www.gewizrepairs.co.uk
1helpful
How do I test if the batteries are still working? I have not ride or switch on the scooter for at least 3 years.
Assuming you don't have a voltmeter and can't check to see if the batteries are producing 12.6 volts, remember that these batteries are around $36 each at Radio Shack and easy to replace if your hands are working. If it's really important, spend the $36.
If your hands don't, or you don't have a Radio Shack, a scooter replace shop locally charges $85 an hour, min one hour, to troubleshoot and diagnose the batteries, then will charge for the parts at around triple the Shack price. I'm sure there is a repair facility similar around your area.
To test the batteries without a voltmeter, charge the scooter overnight, get on in the morning, and starting at the slowest speed, go forward a little bit, slowly working your way up to the full speed. Stay around your charger, IOW don't go for a 3 mile ride, until you know if and how much of a charge the batteries are holding.
One last thought, in our scooter, new batteries only lasted 2 years and 2 weeks before losing their capacity. Our local "small town" Shack had the batteries in stock, so they seem to be a popular item.
I need to find a stackable battery box for my scooter, as well as what batteries are needed. Also, what charger should be used with it? I bought used from a private party-no charger and the small battery...
James your scooter use 2 12-12ah batteries located inside the battery case. Just remove the screws holding the case together and remove the old batteries then replace with the new ones making sure that you repace the wiring just as you removed them from the old batteries you might also have a heat sensor attached to one of the batteries make sure you reattach that to the new batteries. Any off board charger made for power chairs or scooters will work but try to find a 4 amp charger with an on/off switch. Always turn the charger off when plugging or unplugging from the scooter Check on e-bay or with a provider for a charger Hope this helps
I just bought a new battery charger cable called (Sealed Lead-Acid Charger) to replace an older (Lead Acid battery charger). The New Battery charger will charge for about 2 to 5 minutes and then stop...
ismail the charger you bought should do the job. By stop charging do you mean the light on the charger turns from yellow to green? Your scooter has small batteries 12/12 and don't require along period of charging. Now the scooter has a heat sensor for the batteries and will cut off charging when temp of the batteries gets too high. The older charger could have overcharged your batteries and made them weaker instead of stronger. I would suggest you replace the batteries (2 12/12AH) and charge them with the new charger. Remember to reinstall the heat sensors on each battery when replacing. If you have a digital voltmeter set it to 200 v dc and put the leads into the 2 outer plugs in the charger port on the battery pack. You should read 24-26 volts dc when the batteries are fully charged anything less would mean weak batteries. Hope this helps you
1helpful
2answers
How do you change battery on scooter x360
You probably have a 24 volt or 36 volt system. For each 12 volts, you will need 1 battery. Thus, you will need 2-3 batteries. The batteries are located between the footrest in the middle. Some have an access panel. If your model does not have that panel, then you have to remove the seat and plastic body, a very time consuming and annoying process. You may even have to remove the steering stem. Pull out the batteries, TAKE SEVERAL PICTURES of the wiring so you can put it back together exactly the same way. The wires have to be in series. If you screw this up, best case it won't charge properly, worst case you can overheat and damage the batteries, even causing them to explode and cause a fire in extreme cases. The old wires may be soldered on. Just snip them off and install new connectors that you can find at walmart, radio shack, or any automotive store. The manufacturer should have left a little extra wire to allow for this. If not, you may have to remove the solder with a soldering gun and reuse the existing connectors, or run new wire. You probably need 12V7AH, 12V8AH, 12V10AH, or 12V12AH SLA batteries(SLA means sealed lead acid, V means Volts, and AH means Amp Hour). It should be stamped on the side of the battery. 10AH and 12AH are the most common. They should cost about $25-$40 each depending on the supplier and size of the battery. The higher the AH, the more expensive the battery. Once you've changed the batteries, charge them completely before using it. FYI: Always fully recharge the batteries after you deplete them. Letting them sit discharged will drastically shorten their life or even ruin brand new batteries. Also recharge the batteries every couple of weeks, even if you aren't using the scooter. They gradually discharge when sitting. If you keep the batteries charged, you should expect about 1.5 - 2 years out of them for average use. Hope this helps. www.solanocycle.com
Top UPG Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an UPG Computer and Internet Expert? Answer questions, earn points and help others
