Gday and happy new year
hope you may have some advice that may help me with a problem im having
i bought a disc brake conversion kit for my 64 bird
we fitted up the kit with new lines
the ki
First of all, I hope you got a new master cylinder with your disc brake kit. A new master cylinder should be bled before connecting the brake lines and then never allowed to pull in air during the rest of the bleeding process. A couple of fittings ans hoses should have come with the new master cylinder [see the kit listed for a picture]. If the master cylinder has an air bubble, you won't be able to properly bleed the rest of the system.
For the rest of the system you can make up a small catch bottle like the one pictured in the one man brake bleed kit; make sure the hose goes tot he bottom of the catch bottle. You have to cap the master cylinder reservoir before pumping the brakes or fluid will squirt out and all over; brake fluid is a like paint remover. Then start with the brake farthest from the master cylinder and bleed fluid out by having a buddy pump the brakes while you hold the catch bottle above the bleeder port so no air gets back in. [hint, put some pipe teflon tape on the outer threads only, not the inner end of the bleeder screws to seal the threads]. Check the master cylinder level often! If the brakes still are spongy after the first round of bleeding, have a buddy pump up the brake pedal with the bleeder screw closed and hold pressure on the pedal; you then open the bleed port until the pedal goes to the floor; have your buddy hold down the pedal until you close the port. Repeat on all brakes until the pedal is firm.
