The navigation system is not picking up my current location
SOURCE: replacing the battery in a 2001 mercedes benz
Battery base has a device that clamps the battery on a step/notch on the side. Use a ratchet with an extension to loosen. Once it is loose you can remove the battery.
SOURCE: security system on 87' mercedes benz. just bought
under the passenger side false floor in front footwell is the alarm module. Pull the carpet up and remove the 2 10mm bolts from the false floor. There are 2 control units on the backside of the floor. One of them is the alarm module. unplug it and you won,t have an alarm any more. good luck
SOURCE: How do you reset 2006 ml500 mercedes benz
You will need a code reader/scanner called OBD2. They are under $50. A nice one can cost $100-$3,000. Just buy one that does the job...no need for the more expensive ones. You can borrow one from some auto parts stores, like the AutoZone.
You can also pay a shop this much to do it for you, every time.
Just select erase codes, and you're done.
SOURCE: How do I unlock the shifter on a 2000 Mercedes
No you do NOT need a new transmission.
This model Mercedes uses an electronic solenoid in the shift housing, to take the linkage out of park.
There is a small plastic part, activated by a solenoid that pushes a release, allowing the
shifter to come out of park. Most of the parts in the box were metal.
This particular part is plastic and very frail.
It is not an easy job, but any mechanic can do it.
SOURCE: how to reset airbag for mercedes benz c220 1994
This can not be reset by conventional methods. This must be done through a scan tool. Usually only the dealer scan tool will communicate with the SRS module. If the SRS light is on you have other issues and they must be remedied before the light will go out. There is no way of knowing what the issue is without running codes with the scan tool.
