Incline motor runs a few seconds then shuts off incline does not move everything else works
SOURCE: incline does not work
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Testimonial: "Great thanks"
SOURCE: ifit treadmill will not incline but everything
You may need to calibrate the incline. Do this with the following procedure.
Safety key out
press the stop and speed up buttons at the same time while inserting the safety key. (you are now in diagnostics)
press the stop button one time only.
now press the incline up button (incline motor should start moving up)
incline will go up to the top and then all the way to the bottom. when it gets done you can remove the key. Reinsert the key and you should be operating normally.
Good luck Tim
SOURCE: Pro Form C525. Then incline motor works with a
The repair for this is usually a new elevation motor. However if elevation isn't a big issue for for you, you can disconnect the elevation motor and use treadmill like that. The elevation motor doesn't go out that often. You should check with a local repair person. They may have a used one laying around. I usually keep one on hand to test with.
SOURCE: Proform 740CS runs okay but the incline does not
SOURCE: My proform 515s Crosswalk treadmill works for a
1. Inspect belt and deck. The deck should be smooth. The belt should have a consistent feel from side to side (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Continued use of your treadmill may damage expensive electrical components. 2. To inspect the belt and deck visually or to clean underneath the belt before applying lubricant, the belt must have the tension reduced. Loosen the tension roller by following the instructions in your owner’s manual. Do not loosen the bolts in the tension roller too far or the bolts will come out of the roller shaft. This step may not be necessary for your treadmill model or belt and deck condition. 3. Contaminants are the worst enemy of your belt and deck. Some treadmills may have an excessive accumulation of dirt and contaminants. If these are trapped during the belt lube process, significant damage will occur. If contaminant removal is necessary, loosen the belt by following step 2, lay the treadmill on its’ side, and use a nylon brush to loosen contaminants that have accumulated on the inside of the belt. Clean the deck with mineral spirits in a well-ventilated area. Allow the deck to dry before lubing or tightening the belt. 4. After completing the steps above go to your local hardware store and purchase a can of silicone spray ( Pyroil, Napa etc ) attach the nozzle and proceed to spray length wise starting at the motor shroud to 2/3 down the deck repeat the process on the other side then re-tension the belt according to you owner's manual. Start unit and proceed to walk on it if the unit shuts down again then belt and deck needs to be replaced or your in the market for a new treadmill.
