Nokia 1616 Cell Phone Logo
A
Anonymous Posted on Oct 17, 2014
I have to cancel all call barring but i have forgotten barring password what to do
What my Nokia 206.1 call barring password
Unfortunately, the only way to recover your phone barring password on your device is to perform a Factory Reset. This will wipe all of your phone's data to bring it back to its factory settings, thereby deleting the forgotten phone barring password.
The incoming calls whilw roaming is barred and no-one seems to know what code was used. Tried all the usual 111, 0000 etc. Help
Hi, Go to Call Setting, then go to Call barring, you will a outgoing calls,incoming calls, activate all, cancel all & Change barring password. choose the "cancel all" then the call barring password is 0000. if still the same maybe someone change your barring password. try to talk to your friends to know who made it.
Apr 25, 2011 • Cell Phones
2helpful
I don't know what is the password of call barring belongs my cell phone SGH-L760
hi,
Before you can activate these barring services you will need a barring code from your service provider. Call Barring can not be activated if Call Forwarding diverts are already in use.
To Activate: * 330 * BARRING CODE # [SEND]
To Cancel: # 330 * BARRING CODE # [SEND]
To Check: * # 330 # [SEND]
All Outgoing Calls
To Activate: * 333 * BARRING CODE # [SEND]
To Cancel: # 333 * BARRING CODE # [SEND]
To Check: * # 333 # [SEND]
All Incoming Calls
To Activate: * 353 * BARRING CODE # [SEND]
To Cancel: # 353 * BARRING CODE # [SEND]
To Check: * # 353 # [SEND]
All Outgoing Calls
To Activate: * 33 * BARRING CODE# [SEND]
To Cancel: # 33 * BARRING CODE # [SEND]
To Check: * # 33 # [SEND]
All Outgoing International Calls
To Activate: * 331 * BARRING CODE# [SEND]
To Cancel: # 331 * BARRING CODE # [SEND]
To Check: * # 331 # [SEND]
All Outgoing International Calls Except To Home Country
To Activate: * 332 * BARRING CODE# [SEND]
To Cancel: # 332 * BARRING CODE # [SEND]
To Check: * # 332 # [SEND]
All Incoming Calls
To Activate: * 35 * BARRING CODE # [SEND]
To Cancel: # 35 * BARRING CODE # [SEND]
To Check: * # 35 # [SEND]
All Incoming Calls When Outside Home Country
To Activate: * 351 * BARRING CODE # [SEND]
To Cancel: # 351 * BARRING CODE # [SEND]
To Check: * # 351 # [SEND]
Canceling All Call Barring # 330 * BARRING CODE # [SEND]
i hope it will help you...
Apr 13, 2011 • Cell Phones
2helpful
Hi, i have purchased a nokia E71 on Ebay which was described as unlocked.After recieving phone i put in a Vodaphone prepaid sim only to find call barring was activated.I then contacted seller to find he...
Hi
the default is 0000 or 1919 or 1234
Call barring
Call barring (network service) allows you to restrict the calls that you make and receive with your phone. To change the settings, you need the barring password from your service provider.
  1. Select Menu > Tools > Settings > Call barring.
  2. Scroll to the desired barring option, and to request the network to set call restriction on, select Options > Activate. To set the selected call restriction off, select Cancel. To check whether the calls are barred, select Check status. To change the barring password, select Edit barrings passw.. To cancel all active call barrings, select Cancel all barrings.
So try contacting your Vodaphone customer service and ask for the call barring code, see if it opens up with a code that they give.
Aug 30, 2009 • Cell Phones
14helpful
6answers
Forgotten password on hp laptop
You can reset the password with windows password buster.
See: How to Reset HP Laptop Password?
2answers
Call barring
Use the network services menu for this...
Use this menu to access network services. Please
contact your service provider to check their availability and subscribe to them, if you wish.
This network service allows you to restrict your calls.
1. Select a call barring option:
All outgoing: prohibit outgoing calls.
International: prohibit international calls.
International except home: only allow calls
to numbers within the current country when
you are abroad, and to your home country.
All incoming: prohibit incoming calls.
Incoming while abroad: prohibit incoming
calls when you use your phone outside of your
home country.
Cancel all: cancel all call barring settings,
allowing to be sent and received normally.
Change barring password: change the call
barring password obtained from your service
provider.
2. Select the type of calls to be barred.
home country.
provider.
if you have any queries about your mobile..you can have a look at this user manual which can be downloaded from
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/SGH-D600-_E
hope this helps :)
13helpful
2answers
How to reset a forgotten admin password on a xerox 4150
PRESS # AND ACCSES SIMULTANIUS FOR 3 SECONDS
PASSWORD 1934
How do I enter the User ID codes for a Xerox CopyCentre 275?
The Tools menu is used to set up machine parameters. The menu is protected by a system password, referred to as the System Administrator password. The default system password is 1111.
NOTE: If the System Administrator password has been changed or forgotten, contact Support for additional assistance.
  1. Press the [Access] or [Access A] button on the Control Panel to enter the Tools Mode. The Login screen will be displayed.
  2. Enter your password using the numeric keypad on the Control Panel, and then select [Enter] on the Touch Screen. The Pathway Options screen will be displayed.
    NOTE: The default password is 1111. The password will be displayed as an asterisk (*). If you make a mistake, press the [Clear (C)] button on the Control Panel and re-enter the password. To cancel the operation, press the [Cancel] button. If you are experiencing problems with your password or have forgotten your password, contact your administrator.
5helpful
How di remove call barring from nokia 5500d
Call barring
1 Select Menu > Tools > Settings > Call barring.
2 Scroll to the desired barring option, and to request the
Call barring and call diverting cannot be active at the same
time.
When calls are barred, calls still may be possible to certain
official emergency numbers.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
