Door not closing
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
SOURCE: Sub-zero Refrigerator Door
We have the same problem and were told to apply vaseline to the rubber edges of the door; this did help.
SOURCE: Cannot reopen Sub-Zero 642 freezer door for 50 seconds
Yes, this is normal. My 642 does the same thing. It seals to be more efficient while trying to cool back down after it has lost heat while open.
SOURCE: sub-zero door seal
THE TRUE IS .. replace a door seal is a little pain to replace. YOU HAVE TO INSTALL RIGHT. ( some model using silicon. if you are patient. and able to remove aroun 30 screws. do it. if not. better call a tech........good luck.............................. LEAVE A COMMENT IF IT WAS GOOD FOR YOU
SOURCE: The freeszer door on my Sub Zero does't have suction anymore
what is the mod num> 650, 700? no a lot help. check the freeze inside the upper part for any ice build up
