How do I reset my hp Compaq 6910p back to factory settings?
This is how you put it back to Factory Settings...
1) Press and Hold the F11 key during boot.
If you are unable to get into Windows to start the recovery then you start the process when you first switch on the PC.
As soon as you turn on your PC, tap the F11 key on the keyboard until you get the "Windows is loading files..." message. When Recovery Manager has loaded click advanced options. Choose system recovery.
If you wish to try and backup any data then choose backup your files first and follow the on screen instructions. To run the recovery without backing up your data choose to recover without back up.
The recovery will launch and restore your system back to it's factory default state.
This is how you put it back to Factory Settings from desktop...
1) You can start the recovery from within Windows as follows:
Click Start
Click All Programs
Click Recovery Manager
Click Recovery Manager again
Click next when the Recovery Manager program loads. You will be prompted with several questions before the recovery starts.
"Would you like to perform a program recovery?" - choose no
"Would you like to perform a driver recovery?" - choose no
"Would you like to launch Microsoft System Restore?" - choose no
"Would you like to recover your computer to its original factory condition?" - choose yes
The computer will now restart and launch the recovery program.
NOTE: Some computers are F10.
OR
1) Turn on the computer
2) Start tapping/pressing F12 for Boot Menu
3) Insert HP Recovery Disc
4) Select DVD/CD-ROM and press enter
5) Press any key to start the installation
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00809678&product=18703#RestoreWithoutWindows
I’m happy to help further over the phone at https://www.6ya.com/expert/jonathan_828b54f422cbefdd
SOURCE: Laptop function keys are nt working
2 possible solutions...
Reset the BIOS: Works in most cases
Reseat the keyboard: Sometimes it is possible, that the keyboard connector comes loose and thereby causing a malfunction with some keys or overall fails to work.
SOURCE: factory.settings
According to what you have said, you might have created the Recovery disks after purchasing the notebook.Now you are trying to restore the notebook to factory settings, but they are not working.
Even you have tried to F11 options to restore notebook using the Recovery partition of your notebook.
Let me assist you in this regard.
If the recovery disks are not booting, then we have to check if the issue is with the disks or with the CD/DVD drive itself.
To check that, you need to try to boot with any other OS CD. If the notebook is booting with other OS disks, then the issue is with the Recovery disks itself.
Even F11 option is not working, you have to make sure that D: Recovery is not removed.
For your information, if the issue is with the Recovery disks, then you can purchase the Recovery disks from Hp at very low price.
You can order them from the below link:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=500508
Under
CD-ROM order page - Recovery Discs
you can order the place order for Recovery disks.
SOURCE: How to replace the Keyboard?
i have a hp 6910p laptop and need to know what screws to remove.
SOURCE: how can I reboot a HP Compaq 6910p? It will not
You can get support from Compaq here for your 6910p notebook:
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=3357377&taskId=110
Hope this helps.
