I came home to water under my washing machine. When I looked underneath it appears that the water was coming out from the bottom. All the hoses are dry. No water appears to be running from any of the outlets from the hoses.
Hello Cicl, I appreciate your post!
If you have a water leak from under your Frigidaire washer it could be a possible problem with a faulty water hose, water inlet valve, or drain pump. Either one of those components could be causing a drain within your washer. Since it could be any one of these underlying issues I would suggest seeking assistance from a professional technician to get a proper diagnosis and repair. I hope this is helpful. -Matt
SOURCE: washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
SOURCE: leak coming from bottom of washing machine
It might not have totally emptied during the last cycle. Try laying the hose where the water empties down. The level of the hose needs to be lower than the water level to be able to drain. Make sure you have a bucket to empty in to.
SOURCE: leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
SOURCE: Washer leaking water from bottom
MIne did and it was the bleach container on the top that was getting clogged and leaking over, we actually drilled the hole a bit bigger and cleaned it all out and it stopped. I've had to take the whole top of the washer off to do this about 2-3 times now.
You may want to check the seal at the bottom of the agitator, there is a o-ring that keeps the water in the drum from leaking through the agitator as it spins. This is a cheap seal and will wear over a period of time from exposure to bleach and detergent. You need to take the agitator apart and remove it from the drum and you should see this seal at the base of the agitator were it meets the drum.
Replace the seal and reassemble, take the metal casing off the washer and fill the drum with a little water, wait, and see if the water is leaking under the drum. If no leak, try to reassemble and run the washer. If is still leaks then check http://www.applianceaid.com/genew.html
Yours Truly,
Mr.Fix-it-guy
Hi friend, thank you for your post!
I understand that water is leaking from the bottom of your Frigidaire washer. There are many components that could cause a washer to leak the bellow (gasket), leak from drain hose, drain pump, or water valve. Since it could be any one of these underlying issues I would recommend having a technician come out to diagnose and repair your appliance. Hope this is helpful. -Matt
