I am trying to connect my external microphone but there is no response.
SOURCE: Dell Latitude D610 Laptop wont turn on
Press the volume button and the power button at the same time. Hold them down untill the diagnostic program starts. Let it run it's course. It will stop on the problem. Fix the issue. I had the same issue. It was a simple world clock setting for me. Go figure?
SOURCE: My Dell Latitude D610 Battery Stopped Working
The battery light flashing RED/AMber is an indication of a failed battery.
Portable batteries have a life expectancy of 300 to 500 recharge/discharge cycles. (roughly 18 months under normal use) After that, the charge life starts to drop off and eventually it will not hold a charge. Because of this, the battery is considered a consumable item and is only warranted for one year from the manufacturer.
Since all the systems listed in the post are D610's (4 to 5 years old) it is not surprising that the batteries are failing.
Dropped Puck, if you replace the battery and a new battery doesn't charge/run the system, then the charging circuit on the MB is failed.
SOURCE: my dell laptop latitude d610 have no audio sound
Go to the DELL support page
http://support.euro.dell.com/support
Click drivers & download
enter your system type and model
You will then be presented with all the drivers for your D610.
Download the Sigmatel driver in the Audio section.
Save the file then run to install the driver.
SOURCE: DOWNLOAD OF DELL LATITUDE D610 SOUND DRIVERS
You can download the DELL D610 driver from the link below. You can also download all other drivers and utilities from this link.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WLH&osl=en&catid=&impid=&SystemID=LAT_PNT_PM_D610
SOURCE: I cannot do a Print Screen with my Dell Latitude
Based on your keyboard layout, you don't need a key combination to capture your screen. Just press the "Print Scrn" button and your screen image will be copied to your clipboard. Now if you have pressed the "Print Scrn" key, go to MS Paint or any other image processing programs and "paste" it there.
Notice that your "Print Scrn" key is printed on top of the keyboard key and in white color. That means that it is the default key when pressed so there is no need to combine with Fn or shift. But if it is printed in blue or orange (your Fn key should be in blue or orange also) that is the time you need a key combination.
