SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
SOURCE: maintenance M2 call service
M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.1-Press utility button on panel.2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.3-its the code to get into service mode.4-After pressing above mentioned buttons you will enter into service mode.5-Now select service choice option.select it by pressing OK button.6-In service choice option you will see Maintenance count option.7-Select it by pressing Yes or OK button.8-There will be three options 0,1,2.9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
SOURCE: m2 error service maintenance
m2 for km 163 or 7216 or equivlent models - it reaches alredy the copy life of the mchine consumbles like drum nd developer, you hve to replce it nd reset the progrms
SOURCE: proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
SOURCE: how to clear on shown display in konica minolta maintenance call m2 call service
Konica minolta bizhub 215 showing maintenance call(m2) and service callProcedure1. Press the COUNTER. (UTILITY)2. Press the following keys in this order:STOP 0 0 STOP 0 13. Enter the code number corresponding to the function to be used from theKEYPAD.4. Press the START.< Exiting the Mode>
• Press the AUTO RESET until the initial screen reappears.
Utility-stop-0-0-stop-0-1 for service mode. choose clear data, then supply countthen ok to clear. On/ Off the machine it will work as usual.
