Miller 44g welder has small arch but wont weld
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
SOURCE: what setting do I need to weld aluminum for a 135 miller mig weld
start slowly turning up the wire feeder,and the amps till you get the sound of bacon crackeling and youll know your there. hope this helps jojogunne
SOURCE: Can't get 110 threw the welder.....
probably fried the board....you probably cant see it but thats what will happen
SOURCE: where could I find a circuit diagram for a mille
miller online. you will need all info off the data plate
SOURCE: Miller mig welder #175 stopped
This usually happens when the main Power semiconductors fail. You need to check out the two main places, the Power Supply, make sure ALL voltages are correct, and the main Output semiconductors, check these to make sure they are Not open circuit or short circuit.
http://www.millerwelds.com/service/ownersmanuals.php
Above is your support link.
You need to contact Miller and obtain a service manual, before attempting to service this unit.
