support.google.com > ... > Help > Account > Sign in and out
GoogleSo when using a public computer, be sure to sign out. ... Open Gmail. ... If you've forgotten to sign out of your email on another computer, you can sign out of ... saved on the login page; Sign out; I can't sign in on my mobile device or email client.
GoogleThis troubleshooter will guide you through 2-5 questions, depending on the options you select. ... I know my username and password, but I can't sign in. I can't ...
If a username is already filled in and you need to sign in to a different account, click Sign in with a different account.
If you see a page describing Gmail instead of the sign-in page, click Sign in in the top-right corner of the page.
SIGN IN TO GMAIL
Public or shared computers
If you're using a public or shared computer, be sure to sign out of your Google Account before leaving the computer. Learn more about signing in securely to Google.
If you are using computer that is not your own, then you can google go to gmail.com and sign in.
If the computer you are on already has a gmail account, then you will need to sign out of it first, before you can sign in to your own gmail account.
In order to sign out of one account and sign in to another, follow these steps:
1. When you are in gmail, click on the icon in the top right corner.
2. Click on "Sign Out".
3. On the "Sign Out" page, click on "Sign in with a different account".
4. Here you should be able to access the gmail account you prefer, as well as delete ones that you don't want.
Make sure that you sign OUT of your gmail account when you are done, otherwise, your gmail will come up on that computer as the default gmail account.
There is a menu item at the upper right corner of the screen with the word Home. Next to it is a little "down" arrow. Click that arrow and choose "sign out"
you just click on sign in as a diffrent user , the person name will be out and then you sign in your user name and password.then click sign in.then it will open your.then you chat.
It may cause of 2 different reasons:
1. Maybe some one else has your password (or you hacked) and he/she really use your ID from other computers.About this case, if you can sometimes sign in yet, I suggest you to change your password on other computer (Not your computer) because maybe your compter has infected by trojan and if you change your pasword, the new password will send to that hacker again! so do that in other computer (A clean computer!) and then try to kill trojans on your system as soon as possible.
2. The second reason is cause of some problems on yahoo that will fix!
So as I said, you should find the source of problem, check signing in by other computer, if it sign in, so the problem comes from your computer.Try to fix it!
Good luck
