You need to stop the print before it is finished to determine the source of the issue. Most likely sources are the black drum or fuser. Please note: as I hope you will stop the passage of paper before it passes the fuser assembly, the toner will not be fixed to the paper and can/will be smeared. Also, visually inspect both drum and fuser for the line. If you do see the line replace that assembly.
SOURCE: problem printing with Dell 3010cn Laser
Check for damage to the fuser located right were the paper exits. damaged fuser can cause lines
SOURCE: My DELL 3010CN is printing a thick black line on
Often Toner sticks to fuser. When the fuser heats the toner comes off onto the paper. Should reduce over time unless toner is spilling onto the fuser in the same place.
Change fuser and toner
thanks
SOURCE: white stripe on right as if black toner needs
We have the same problem.
Can you tell me where do I find the image path?
Thank you.
