Sharp MX-2300N Color Copier Logo
Best Med Posted on Oct 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sharp mx 2300N error code U2-41
I have a error code U2-41 with my sharp MX 2300N and i cant enter in SIM MODE how i can solve this problems
  • Steve Gwynne Oct 19, 2014
    Hi when you say you can not enter the sim mode, can you explain why?
  • Mutemwa Kapui
    Mutemwa Kapui Oct 31, 2017
    what machine is that if its sharp MX-2300N the enter sim and clean it by using sim 16.
    to enter press copy mode on the touch screen the press P asterisk * C * asterisk.
    if the problem persist the replace the controller board.
Ethan Marvick
Level 2:
New Friend:
  • Expert 71 Answers
  • Posted on Dec 02, 2014
Ethan Marvick
Expert
Level 2:
New Friend:
Answers
71
Questions
0
Helped
37490
Points
102
The U2 errors are usually related to memory or board level issues. You should try to disconnect the fax and network and then kill the main power inside the cover. Turn the main power on and then when you get a solid green light on the control panel press that power switch. If the machine boots with everything disconected then try conecting the options one at a time and try rebooting each time to see if you can narrow down the problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Mar 09, 2010
SOURCE: Sharp MX-2300N with error code H3-00. . how do I
Ensure you are in COPY mode
press # * C * ( one after the other, fairly quickly)
when the screen changes enter the number 14 on the keypad
press the B&W start button
press 1 for Yes when the question displays
press thw CA button
machine will re-boot and fault should clear. If it doesnt you need a service engineer. This is a fuser temperature fault
A
Anonymous
  • Posted on Jun 01, 2008
SOURCE: error code h5-01
Yes H5-01 is when it jams in the fuser 5 times in a row, check the fuser section for a jam, the paper jams up in there and does't trigger any sensors, once you have confirmed that its clear reset with sim code 14
Anonymous
  • 95 Answers
  • Posted on Jan 15, 2010
SOURCE: sharp mx-2300N printer error maintenance required
VK means black developer has reached end of life. You can safly carry on using the copier with this message displayed but over time the copy quality may slowly degrade. You will need to call a Sharp authorized dealer to replace the developer in the developer unit.
Anonymous
  • 11 Answers
  • Posted on Oct 11, 2010
SOURCE: how do you select an
To set an IP address, go to the system settings page. Enter admin mode (password if unchanged should be "admin") on page 2 select network settings and then ip address settings. Input your required info and switch machine off and back on when instructed.
I hope this is the info you needed.
Good Luck
Anonymous
  • Posted on Nov 17, 2011
SOURCE: network printing from a mac computer to sharp mx 2300n printer
Here's a new solution that works. When adding the printer, choose "Generic PCL Printer". This will allow you to print from your Mac to the Sharp Printer without buying the PostScript chip/kit for the printer.
A LOUD NOISE WHEN I TURN ON MY COPIER SHARP MX-2300N AND IT CAN NOT COPY OR PRINT
Hi Patience .
Have you got anything on the display ?
Any error codes ?
2answers
Sharp mx 2300N error code H5-01
http://www.copytechnet.com/forums/sharp/76512-sharp-mx-2300n-error-code-h5-01-a.html
2answers
How do I fix the error code 'U2-30'on my Sharp MX 2300N color copier?
please reset the machine by eject the power and data cable for a one minute and also re installer the printer driver
Sharp MX-2300N Maintenance Required: Code VC
Time for some scheduled maintenance! Call a local sharp dealer.
google sharp service locator, enter your model and your zip code to find a dealer near you.
Copier Collin Houston TX Copier and Imaging Expert
2answers
Mx-2300n firmware
The firmware is only available from a dealer. You can make an arrangement to get it on a USB thumb drive and update the machine using SIM 49
I need to enter simulation mode on Sharp MX-M260N. Also, I am looking for the MIB code to enable/disable copier via SNMP
Simulation Mode is # * C * What do you mean by the MIB? I know that you can setup settings for the SNMP on the webpage of the copier. Have you tried that?
Code:fk1 sharp 2301 N
That is a maintanence code. Usually says that the fuser rolls are at a certain copy count.
Here is what to do.
Press in order on the consol. # * C * That will enter the machine into what is called SIM mode.
Then enter the number 24 then 4 for that code, then press execute. You may want to just do the clear all maintenance code too.
13helpful
Sharp MX-2300N with error code H3-00. . how do I fix it?
press thw CA button
33helpful
5answers
Network printing from a mac computer to sharp mx 2300n printer
HI,
Sounds like driver problem..
go to this site: Driver Update and make required updates.
wish you best of luck
cheers
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
