F-20 code displays and wash stops in the middle of cycle.
A possible solution to an f 20 fill error for a whirlpool duet washing machine. Blow out the pressure hose that connects to the pressure switch.
Before doing any of these fixes first ask yourself if you have over loaded the machine. Too many Bulky - heavy items will cause this same message.
How to fix Whirlpool Duet F20 Error:
Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the F20 error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
If water pressure is good, check the water valve inlet screens. Most residential washing machines have inlet screens. The screens prevent minerals from clogging the solenoid. With the hoses removed, you can visually inspect the water inlet screens. If the water valve screens are clear the inlet valve with the screens itself will need to be replaced. To replace the water valve, remove the top of the washing machine. Three screws hold the top down. The screws that hold the top down are on the back of the top panel. Once removed the top will slide back and off. Now remove the wire harness that connects to the valve. One screw holds the valve to the washers cabinet. Removing the screw and sliding the valve over will release the valve from the back panel enabling you to complete your repair.
One last thing to check is the fill hoses. These front load duet washers call for a lot of water quickly. So if you have stainless steel braided flood-safe hoses, they will trip for no reason at all. Replace these flood safe hoses with more traditional hoses.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/#sthash.zTyr5Yy1.dpuf
SOURCE: error codes
If this machine is like other of its type then you may find the manual taped to the inside of the machine near the bottom side panel.
open the bottom access panel (3 screws on bottom front lip) and look for it as it will have the codes. near where the filter is .
while you were down there cleaning the filter did you check that the pump impellers move freely and were not clogged with any debris.
SOURCE: Error code SD
I work for an appliance company in the service department, and what this really means is that you could have a suds build up in your machine, or that you used too much soap on this particular cycle. If starting over does not work, you can buy a product called washer magic at almost any store and it will clean your machine out. Also, running vinegar through the machine will make any suds dissapate.
SOURCE: F-05
F05 machine means "Pressure switch jammed"
Try first cutting power to the machine for two minutes, if that reset the code, then the problem was temporary.
If not :
Check if the machine drained, or if water is not being drained.
If drain system works .take off the the lid , locate the switch, it must have a small hose attached.
Remove the rubber hose attached to it, and unlock it by blowing into the hose.
If the water does not drain,
this will also cause the pressure switch error.
In this case check the drain hose , and the drain pump.
Finally, ta faulty timer control board can cause the error, you test the control PCB if lid switch and drain system are OK.
SOURCE: Maytag Neptune Error COde "nd"
This is now the 3rd time this has happened. The 1st 2 times it cost me ~$100 to have a technician come in and fix.
This time, I did it easily. For my Maytag Neptune washer, I removed the back panel (2 screws). On the bottom tray is the water discharge pump. On the output side of the pump there is a small cavity under the rubber flapper where a nickle fits perfectly. I removed the nickle, reattached the output drain line. started it up ...
and viola! the problem solved.
SOURCE: After about 5 minutes into
I just had this problem. My water supply (hot ) had been turned off since my husband used it to fill our hot tub. Other causes were-supply hose kinked,strainers in supply hose clogged, water pressure too low. Hope this solves your problem!
