The microwave above the oven fall on top of the oven- it shattered the stove top. Can the top be replaced or is the oven all done
SOURCE: Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
SOURCE: I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
SOURCE: The glass has shattered in my electrolux eou6330x door
It will be difficult to find just the glass, have it shipped and fumble with getting it into those factory sealed doors. The entire door can be purchased for right about $50. Click here to see. There is not a picture associated with this item, but it is the correct part number.
GOOD LUCK AND PLS RATE THIS POST!!!!
Testimonial: "thanks"
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
