PRIMER BULB WANT PUMP HARD
SOURCE: engine won't run unless primer bulb is being pumped
I have the same problem and may have a solution. I looked at the primer pump and it was cracked letting air into the system. When I pumped it my finger was over the crack and it worked fine. When I stopped the crack was able to **** air again. Take a look.
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
SOURCE: 6hp Johnson outboard stalls & quits
go to an auto parts store and get a can of gasoline additive called seafoam. Read the label so you know how much to add to your 6 gallon tank. This stuff works wonders on outboard motors.
yes. OR you have an air leak in the fuel system. Easy way to tell is with a clear fuel line between the fuel pump and the carb. If you see bubbles, you are looking at a new fuel line connector or aire leak at the fuel pump. If you pump up pressure with out the motor running A fault may leak gas.
