Antenna may have a dead short or is open, there may be water in the cable, SWR is beyond the scale of the SWR meter.
Check all connections, make sure you have the radio and the antenna well grounded. if possible disconnect both ends of the coax cable and test cable with a ohm meter for a short or open.
Test the SWR meter on a known good antenna and cable if possible.
SOURCE: SWR calibration waaay off the chart
double check your connections and your cable for shorted PL 259 connectors. Oil filled antenna! Humm Sham on you if you are using a liner! Oh and quit sniping the antenna remember the higher in frequincy the shorter the antenna and longer for lower in frequincy. So it could be just where the antenna is located some antennas work good there but a diferent one wont try another spot also make sure your in a clear area when checking SWR not your drive way next to the garage or house or other car and finaly use an external SWR meter the ones on the radio some times SUCK.
SOURCE: Cobra 29GTL Won't Transmit
if the red ant light comes on this means that you have antenna trouble either in the antenna itself or the coax but this should not have anything to do with the radio not transmitting. it sounds to me that you have a bad audio chip or a bad power output transistor. in either case you should really take it to a cb shop and let the professionals solve your problem, good luck!!
SOURCE: My Meter Won't Move
weather can effect your meter .Those meters are not very accurate just a base line get a good swr meter and then check it.If your getting good radio checks it could be the potentoimeter is dirty . Radio shack sells contact cleaner and lube try cleaning it . That might help
SOURCE: red ant light
The red light always comes on while mic is keyed. It is designed to do that. It will blink on and off while mic is keyed if there is a SWR problem. This is explaned in operaters manual.
SOURCE: swr meter not moving.
If the radio is working don't worry about the meter unless you absolutely want it. These little meters are not very accurate or reliable. Get an external SWR meter to check the antenna.
