Peg Perego John Deere Gator HPX Ride on Toy Logo
Posted on Jul 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can i get a replacement rear wheel for a 12v hanma h2 ride o hummer?
  • rswagstaff Jul 07, 2009
    thanks for the info however its a hanma h2 hummer wheel i require and not a pegero!!
romney2012
Level 2:
Habit-Forming:
  • Expert 156 Answers
  • Posted on Jul 10, 2009
romney2012
Expert
Level 2:
Habit-Forming:
Answers
156
Questions
0
Helped
129352
Points
364
I get my Peg Perego and little tikes hummer parts from http://www.shopjandl.com/
I had a difficult time finding these wheels but these guys helped me out.
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jul 06, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
16290
Points
18
I only have 5 volts at the fuel pump on my 2003 h2 hummer
You may have damaged the wiring to the fuel pump speed control module or the module is defective, have the local GM dealer test the system performance to confirm this.
Hanma h2 ride on no power
have you ever used this machine before?
Replacement gear box for a 12v 4x4 hanma hummer jeep
check the wiring to the reverse forwards switch most likely its the wiring
Jul 23, 2012 • Toys
Do you drive.in two wheel or four wheel drive, how do you change.to two wheel drive?
The Hummer H2 and H3 are both all time 4WD. There is no way to put it in 2WD. Now, you can select 4WD High or 4WD Low. You can also, if your vehicle is equipped with it, lock the front or rear wheels through the differential selector. This is one of the primary reasons Hummers get terrible gas mileage is because they are always in 4WD.
The only other solution is to swap the transmission to an Allison 6Spd, which is often done with diesel conversions, and they usually give you a 2WD option, and can get up to 25 MPG out of an H2.......but that conversion is about $30k.
2helpful
2answers
How many hours does it take to replace rear air suspension for 2003 hummer h2?
we got a 03 h2 and had same problem took to dealer and they said on board air compressor went bad wanted 3000.00 dollars to fix,i said bull and went to strutmasters .com and got the coil spring replacements fixed it for about 300.00 bucks rides perfect and we dont have to worry about those damn rear airbag suspension any more,hope this helps someone
I'm trying to find the maufacturer for a battery powered ride-on
I have a broken Hunma H2 4x4 Childs ride-on car.
A cog/gear is broken in the gearbox (the box that enables reverse to be selected).
Where can I get one from ?
Many thanks
Nov 23, 2009 • Hummer Toys
H2 Hummer wheel not working
Take off the seat and make sure that the wires are connected. If they are connected, go ahead and take the two wires from the good motor and put them on the motor not working.
If it still does not spin, then I would get the little tikes motor gearbox assembly from
http://www.shopjandl.com/.
They are repair technician's and know there stuff (they help me with my ride on toys)
Hope this helps
1helpful
I need to remove the rear tires on a little tikes hummer h2,
I would take a pair of pliers and pull off the push nuts.
You have to replace the push nuts with new ones, but when you purchase the little tikes hummer wheels from http://www.shopjandl.com/kids---baby-ride-on-toys-little-tikes.html
they provide the push nuts with the wheels
4helpful
5answers
Air Suspension for 2004 Hummer H2
hummer h2 hydraulic keeps running depleting battery.
Top Peg Perego Toys Experts
john h
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
