Try to create a new profile in MS Outlook that will help you but if you want to access your email data in your Outlook data file then simply use completely free software that will do your job in an easy way.
PST Viewer Tool is helpful to provide you the access to view and read corrupted as well as healthy PST file without using MS outlook application.
Same goes for OST Viewer Tool.
Complete preview of data with the Free Viewer Tool provided by DataRecovo
SOURCE: outlook express
Ok, so you imported your mail to outlook. Then you didn't like the program, so you exported the mail out of outlook. I am assuming you used outlooks export feature, found under the file menu on the top. When you hit export you get the option to name the export file, choose where you want it saved, and choose what type of export file you want to make. Outlook can export a file into many different file types that many different e-mail clients can use. That being said, if you are using the web based comcast e-mail there isn't a way for you to import e-mail into it. Depending on how you set up the outlook account it may have been storing a copy of all the mail it downloaded in both outlook and on the web site based e-mail. As I said, this is entirely based on the settings you selected, if you told it to delete the mail from the server when outlook retrieved it then you're out of luck there. Website based (POP) e-mail accounts are limited in functionality, but tend to be designed for the basic end user in mind. So you're going to lack a lot of the features an actual program like outlook would give you. Peter
SOURCE: Outlook 2007 would like to get rid of default account
Try this:
Create a "fake" email account that has an invalid username/password to a (real) SMTP server (Outlook requires that the SMTP server is real). And then set that as yourdefault account.
Now, whenever you accidentally forget to select the correct account, the default is selected and the message will try to send through the invalid account and pop up an error message. You can then go into the Outbox, select the right account, and re-send.
SOURCE: Office 2007 Update - Outlook not working
Open OL 07 -> Tools -> account settings -> Under the "E-mail" tab -> Check how many account you have. You should see 2 e-mail accounts and if both are the same, delete one account which is not set as DEFAULT.
Reason: When you opened OL 07, it checks if there is any e-mail account setup in Outlook Express ( Win XP) or Win Mail ( Win Vista ) and migrate the account settings.
No E-mails in blackberry :
Open OL 07 -> Tools -> account settings -> Under the "E-mail" tab -> Select the e-mailaccount and click on CHANGE -> Go to More Settings -> Advanced -> Enable " Leave a Copy Of messages on the server"
Reason : Outlook must be downloading all the e-mails from your server when it look s for new mails on the server due to which Blackberry does not detect any -mails on the server.
