Wont turn on
Hello.
The most common reasons are your batter and power adapter.
Disconnect all cables, flip the laptop, unlock and remove the battery. Reinsert and lock, connect the power adapter and try again.
If still a problem, disconnect all cables, flip the laptop, unlock and remove the battery. Connect the power adapter again. If it works, your battery is faulty and needs replacement. if it doesn't work and there is no light on the adapter, your adapter is probably faulty.
Also, try this: wiggle the power adapter where it connects to the laptop. If the power goes on and off, the power jack is faulty and needs soldering or replacement. Leave that job to an experienced tech.
Hope this helps.
