Question about Konica Minolta Bizhub Press C6000 Copier
Por que impressora konica minolta bizhub c6000 apresenta error 2703
Zetty283@gmail.com
  • Konica Minolta Master
  • 6,850 Answers
Check the Cyan Charge Corona housing. Remove it and reseat it. IF not that check the HV board. and or connection at the back of the drum and transfer middle assy.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Dec 28, 2015
SOURCE:
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
herminio_hal
  • 210 Answers
SOURCE: How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
Posted on Jul 09, 2009
  • 6 Answers
SOURCE: how to fix error c0f32
C0F32 is relatd to Developer, enter in to programming............. utility, stop, 0, 0, stop, 0, 1
Adjust...... ATDC Gain if for example 142 ,make it 152 then see, if problem remain same then change Developer, as i had experience Konica 7115/7118/7120/ minolta di152 Drum , Developer are same,
Hope it wil help
Posted on Apr 09, 2010
xeerie
  • 347 Answers
SOURCE: REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA
to remove code "COF32" from your machine, simply change the developer with the new one. code will remove.
wish you best of luck............
Posted on Jun 17, 2010
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
Error code C-2703 Bizhub 500
bersihkan rumah korona bawah, dan ganti kawatnya
Aug 02, 2015 | Konica Minolta Bizhub 500...
Rror 2703
Subject:
C-2702 and/or C-2703 code.
Description:
Solution:
PROBABLE CAUSES:
1. Failed T/S corona.
Remove the T/S corona unit. If blank copies can be printed without a service code appearing, replace the T/S corona unit (p/n 57AA R715 00).
2. The HV unit has failed.
Replace the HV unit (p/n 56AA 8401 2).
Oct 16, 2014 | Konica Minolta Bizhub Press C6000 Copier
How can i reset my gmail password or create a new gmail with my current gmail
You can plug it into a computer and get them that way
Sep 17, 2014 | Google Gmail
How to delete gmail account
If you decide that you don't need your Gmail address anymore, here's how you can remove Gmail from your Google Account:
  • Sign in to your account at accounts.google.com.
  • At the top, click Data tools.
  • In the Data Tools box, click Delete products.
  • Click Remove Gmail permanently.
Sep 04, 2014 | gmail.com
Konica bizhub press c6000 AA errors
What is the error code C-XXXX or SC-XXXX or Jxx-xx what was it doing when it happened?
Jun 05, 2014 | Konica Minolta Bizhub Press C6000 Copier
Konica minolta bizhub 7000 controller doesn't turn on
Turning the Power On or Off - Konica Minolta Online Manuals
manuals.konicaminolta.eu/bizhub-C554-C454-C364.../id10-0061.html
bizhub C554 C454 C364 C284 C224 ... The Main Power Switch of the machine and thePower key on the Control Panel. No. Name, Description. 1. Main Power Switch. Press this switch when turning on or off the main power of this machine or ...
[PDF]C7000/C7000P/C6000/C70hc/ C6000L
myworks.sindoh.com/upload2/.../d37800822888835787371.pdf
KONICA MINOLTA Confidential. 2. C-2721, Intermediate .... v) Execute Printercontroller calibration for every output profile. (Standard ..... Start CWS5 and login to a Fiery controller. ii) Click [Calibrate] ...... If FD skew doesn't remain,. FD skew ......*A1DURX01: For bizhub PRESS C7000/C6000 and bizhub PRO C6501. 2.
Feb 15, 2014 | Konica Minolta Konica Kit For Bizhub Press...
IC 601 controller is connected to my konica minolta bizhub C6000 printer but display is showing controller is not connected
check the cable between the print controller/firey and the copier, also is the print controller/firey set up for a c6000
Feb 07, 2014 | Konica Minolta Office Equipment & Supplies
Coleman.linda321@gmail.com
goto home page of gmail
www.gmail.com
enter your email id and password
Jan 27, 2014 | gmail.com
Code d'erreur C3505
Fusing error have tech look at and reset
Jan 24, 2014 | Konica Minolta Bizhub Press C6000 Copier
Konica Minolta Bizhub Press C6000 Copier Logo
127 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
