Touch screen not responding to touch
SOURCE: touch screen doesn't work
The photosmart c6180 does not have a touchscreen feature. You can check all of the features of this printer on our website HP.com.
Jiffy Epe
HP Technical Support Representative
SOURCE: How to unjam a paper
Depending where the jam is you need to follow the appropriate solution. There's also a video on HP support website on how to clear a paper jam out of your HP Officejet 6500A Plus printer: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02441153&tmp_task=solveCategory&lc=en&dlc=en&cc=au&lang=en&product=4083977
SOURCE: HP LaserJet M4345 - The
Calibrate the control panel Use the following procedure to calibrate the control panel: 1. Turn the device off. 2. Press and hold the # key and the C key. 3. Turn the device on. 4. When a small white square appears in the upper-left corner of the control-panel display, touch the square with a stylus. 5. When a small white square appears in the lower-left corner of the control-panel display, touch the square with a stylus. 6. Allow the device to finish the boot process.
Hope this helps.
SOURCE: hp officejet 6500A printer won't
Welcome to Fixya
Looks like this is a common issue for this printer when printing checks. Go to printer preferences from the print dialog, and then set the printer paper to "Other Inkjet Paper" and try to print again.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: hp officejet 6500a plus error
Hi try these solutions.
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32\ and press enter")
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
Please try this solution.
Remove the USB cable into the printer and leave the printer on.
Remove all the cartridges.
Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
Disconnect the power cable and from the power source supply.
Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes
Reconnect power cord and turn on the printer.
Return all the ink cartridges and close the door. Wait for the calibration process.
Print the test page to check if it working.
Reconnect the USB cable and try to print again.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
