Need sim card unlocked
Here's how you do it:
To get the unlock code, go through here - Unlock Alcatel Phone ' Unlock Code - UnlockBase
To know more about the details of unlocking your other Alcatel devices, read the complete guide here - How To Unlock Alcatel Phone, Hotspot, and Modem
To unlock your Alcatel Ot-5020 from carrier lock, use unlock code You can get it from any of the online vendors like Mobile-Unlocker.com to unlock it .
SOURCE: How do i unlock a sidekick 3 with SIM6 code
Go-to Your Retailer Where You Brought The Phone And tell them "hi i got locked and i cant unlock it i don't want to buy a sim card is there any way you can fix this?"
SOURCE: how do i unlock my tmobile sidekick 3 when i enter
call to your network customer care ..they ll provide u the code to unlock
SOURCE: the t mobile samsung t219 unlock pin code for sim
HI If you are asking for pin contact your service provider , he will give you a default pin . If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Donot try PUK code many times or else your sim will be blocked and you will need a new sim.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
SOURCE: i have a G1 but i forgot my pattern so i reset it
No you dont need to buy an unlock code if you simply forgot your password code, all you must do is do a hard reset on the phone. and yes you can use it prepaid or with whatever plan you want, all you do is insert your tmobile sim card, i have a flex account with tmobile and i just inserted the sim card, You dont have to contact tmobile.
Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.Now to wipe the device clean:
Press Alt+L. Press Alt+W for a factory reset.
Press the Home and Back keys again for about 25 seconds.
The device should then reset again and the hard reset is complete.
