Open DVR cover then locate a micro switch in Main Board.
when DVR switched off keep pressing this switch and then turn on the DVR.
keep switch pressed until you hear 3 or 4 beeps.
or a message appear on screen. Resetting to the Factory Defaults.
There are 150 different shapes and sizes of micro switches available. Need the male and model to give proper suggestion. Please advise what function is controlled by the micro switch.
E43 error motortime out refers to the brew unit not being "sensed" by the micro switch, the most common fault is the micro switch failing. other causes are the failure of the brewmotor itself, or bushes within the brewer. The micro switch is simple to replace as its obvious withits location. the other however will require the expertise of an engineer.
The most common cause of an OE error code on a modern LG dishwasher is: 1. Blocked drain hose 2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction) 3. Failing drain motor. else you need to REPLACE THE PCB POWER CONTROL BOARD
if that doesnt help you.....
the
problem IS NOT necessarily a blocked drain hose or the drain pump it
could be the thermostat micro switch!!! the thermostat is located at
the rear of the right bottom side of the dishwasher(held by oval nylon
plastic housing). Turn the machine off. remove the right side
panel.(remove top {2screws in lid at back}, remove right panel screws
{2 behind door, 3 bottom back panel, 2 behind panel below door {pull
panel out from top [no screws pushes in & out of place]}. Locate
oval nylon/plastic shape located as above - micro-switch is in the
middle (3 wire connectors in 1 block) thermostat is 2 connectors ( 1
each side of micro-switch). use screwdriver to push thermostat back
into the nylon housing on both sides (it has worked its way out a bit
over time and stops the micro-switch working). Reassemble and
dishwasher starts to work again!!!!
When the trigger is released, pressure builds up and this acts on a valve (spill valve or pressure control valve). When this pressure is big enough it will push the spill valve out and closes a micro switch. Now this Spill Valve gets stuck sometimes, mainly due to soap and chemicals...so the micro switch is not closed...so the machine contiues running. If this is left likee this it will cause damage to the valves. So all one has to do is service the spill valve or as I usually do I replace it. There are cases were the micro switch is damaged also..and needs to be replaced. To see the spill valve and micro switch you must open the cover. The spill valve is located where you see a cover with an electric wire coming out of it. If the micro switch is good...you must tackle the Spill valve.
Regards,
fulltech.
It has a micro switch that activates the pump .Look at page 9 in this manual for switch location.
That should be the float control for this system the micro switch. Hope this will help you out.
there is a micro switch that the metal rim of the filter that must contact in order for the fan to run tha unit to run. a bend or warpage in that metal filter housing will cuase contact problems with that switch causing it not to run
The player can read the card, but it is not going to add more memory space to the player. The function of the card reader is to enable your player to play songs that you otherwise couldn't play because the hard drive is full.
