I have a new goldengulf netbook I have WiFi in my home but the netbook is not working I can't use nothing I don't know what to do will you please help me thanks
SOURCE: i can't get my netbook to hook up to my wifi. Can
it thepends in your router or wi fi settings.. If you are using your personal router make your setting WEP. you can also do the settings manualy if nothing else works. go to my internet connections- right click-select advance and tipe the info. close-shot down and re start your pc....you will have access to your wi fi automatically........
2 - Wireless netbook connection using your home ISP
Another way to get online with netbooks if you're at home is to connect wirelessly to your home router.
It's a very easy process - just turn the netbook on and it will seek out your router. You get a fast connection, good security (if you tell your router to use WPA encryption) and it will usually work anywhere in your house or garden. Several netbooks, laptops or other computers can use your internet connection this way from the same router, so your family and friends can use their netbooks at the same time.
3 - wifi netbook connection out and about
A really cheap way to get online when you're out and about is wifi. Many busy locations - pubs, hotels, shopping malls - have "wifi hotspots" which are simply powerful wireless routers that you can use to connect your netbooks wirelessly to the net.
Some are free and can be used by any computers that are nearby. Others are owned by telecomms operators like BT Openzone or mycloud and you need to pay to use them. Monthly subscriptions or pay as you go are available. So are these free and cheap choices ideal for using with cheap netboks?
For anything other than general browsing on netbooks, beware of wifi. The free ones have no security at all, and the others have password protection, but the data you send and receive is not encrypted. This means anyone in the vicinity could snoop and listen in on what you were doing. I don't bother with wifi for this reason.
See our separate feature on wifi for more about this.
4 - Your 3G netbook connection - at home or away.
netbooks.org.uk/wp-content/uploads/g3-dongle-300x164.jpg" width=240 height=131>
netbook dongle for 3G wireless internet
The final way to connect netbooks to the net - (and yes there are only four ways - I told you it was easy) is using the latest mobile phone network - 3G short for Third Generation. Just like a mobile phone, you can pay as you go or take out a monthly subscription with one of the phone companies to suit your needs. Then, using a little device like a USB stick called a USB modem, or a "dongle" plugged into your netbook, you can connect quickly and securely to the net in most of the UK and lots of places overseas. Some netbooks even have a slot to put your SIM card straight in
If you can use a mobile phone where you are, you can probably connect to the internet using 3G. Many people use 3G to connect netbooks to the net even at home and don't bother with a normal ISP.
Your pc could have a phone line input for built in modem DO NOT use that.
Use the lan inlet connector.When you connect the lan cable it should gain access at once.
Unless your connection is protected by a code.
If you have a wire less connection its probably protected with a code when you set the router up.
You have to enter the code to gain access to your network.
Here is a link that shows you how to repair the connection:
http://www.microsoft.com/windowsxp/using/networking/maintain/repair.mspx
And if you have wire less:
http://compnetworking.about.com/od/windowsxpnetworking/a/automaticwifixp.htm
Good luck.
netbook router ethernet or wireless
3 - Wifi netbook connection out and about
A really cheap way to get online when you're out and about is Wifi. Many busy locations - pubs, hotels, shopping malls - have "wifi hotspots" which are simply powerful wireless routers that you can use to connect your netbooks wirelessly to the net.
If you have a wireless router you must know the password you made when you set the router up.
Try also to look in your controlpanel network and shareringcenter.
Hope this was helpfull.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
