SOURCE: no water flow
Did this unit come with water stops built into the faucet body? Some of the newer faucets have stops built in and they need to be turned on. Also if you aren't going to plumb the hot in, you will need to cap it off but it should run without it unless it has some sort of balance in it. I don't think so though.
SOURCE: moen one control shower faucet is leaking hot water
Try replacing the cartridge first.That's your best bit . Next would be the whole valve. Hopefully, it's just the cartridge.
SOURCE: Moen Single Handle Shower Faucet leak...
the cartridge if defective,replace it and your leak will stop.
SOURCE: Moen L3175 faucet with low water pressure
IS THIS A SHOWER ONLY? IF SO ,I WOULD REMOVE THE SHOWER HEAD FIRST THEN TURN YOUR WATER ON.THE HEAD JUST MIGHT NEED TO BE CLEANED AFTER 11 YEARS.
SOURCE: leaking shower/tub faucet, looking for replacement
Call Moen directly. They will ship what you need to your door, for free.
