I am trying to pair with my iPhone 4 and don't remember my Password.
SOURCE: LG HBM 300 Bluetooth headset
Normally the default password for headsets is 4 zero's 0000, unless you have previously set one with the phone.
SOURCE: Bluetooth HBM-730
just set the bluetooth earpiece to pairing mode and start searching bluetooth devices from your phone.
If you don't have a manual, just post back.
SOURCE: need password, cant find manual
Try putting in 0000, that seems to be the LG default code for their bluetooth headsets.
SOURCE: How do I set my Bluetooth Headset HBM-730 to discover mode?
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select HBM-730 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Hi Ursula Ruth Bunch, I want to help you, but I need to know if you misspelled the model name. I don't know of any LG HBM 730. Are you referring to the LG HBS 730 stereo headset? The one that is worn on the neck?
