Tp link model no .. tl-wdn3200
SOURCE: wireless router through Cisco ASA 5505 series
put the one cable to wan which come from internet and you have to connect the pc or any other connection then you connect in the lan
SOURCE: My TP-LINK TL-WN422G doesn't work on MacOSx
i belive there r no drivers for mac ver for that wirless adapter
SOURCE: Hi, I bought a TP-Link TL-WA701ND
You must setup manually your acces point. First go to control panel, under network and internet you'll find a task, view network status and tasks click on it and in next page go to change adapter settings, find local area connection and right click on it and go to properties, in next window highlight internet protocol tcp/ip then click on properties in next window click on use the folowing ip adress and write in ip adress box an ip from 192.168.1.2 to 192.168.1.253 at your choice in subnet mask box just leave 255.255.255.0 (this apear when you click in these box). Now connect your acces point to the computer via network cable. Then open your internet browser and type in adress box http://192.168.1.254 and hit enter, a pop up will apear and ask for user name and password, write admin in both boxes user and password and hit enter, after that you will be able to manually configure your acces point and setup a name and password for your wireless network, change your user and password for acces your device. Good luck!
SOURCE: wireless adapter tp-link tl-wn321g dont
There are 4 different versions op the TP-Link TL-WN321G.
Look on THIS PAGE how to find the version and download and install the correct driver.
SOURCE: TP-LINK TL-WN727N Driver mac os
As far as I can see from the TP-Link website this adapter is only for PC computers and does not have a mac driver. Sorry.
