Boating Logo
A
Anonymous Posted on Oct 15, 2014
<!-- from fixya rte -->Replace 115 power trim honda - Boating
Jerome Minks
Level 3:
  • Master 3,103 Answers
  • Posted on Dec 12, 2014
Jerome Minks
Master
Level 3:
Answers
3103
Questions
0
Helped
671062
Points
9361
Need a printout from the website, or check with the dealer..its a hydraulic pump setup used to raise/lower the outboard..to plane the boat out..
Honda Jazz 2014 how to replace tailgate lock
Replacing the tailgate lock on a Honda Jazz 2014 involves several steps. Here's a general outline of the process:
  1. Open the tailgate: Begin by opening the tailgate and locating the lock mechanism.
  2. Remove the trim panel: You will need to remove the trim panel that covers the tailgate lock mechanism. This may require the use of a trim tool or a screwdriver, depending on the exact model of your Honda Jazz.
  3. Disconnect the electrical connections: After removing the trim panel, you will need to disconnect any electrical connections that are attached to the lock mechanism. This will likely involve disconnecting the wires from the tailgate lock switch.
  4. Remove the old lock mechanism: Next, you will need to remove the old lock mechanism. This may require the use of a socket wrench or pliers, depending on the type of mechanism that is installed.
  5. Install the new lock mechanism: Once the old lock mechanism has been removed, you can install the new one. Make sure that the mechanism is securely fastened and that all electrical connections are properly reattached.
  6. Reinstall the trim panel: Finally, reinstall the trim panel that covers the lock mechanism.
It is important to note that this process can vary depending on the exact model of your Honda Jazz, so it is always a good idea to consult your owner's manual or a professional mechanic for specific instructions and guidance. Additionally, it is recommended that you wear protective gloves and safety glasses when working on the tailgate lock to avoid injury.
Evinrude E-tec 115 hp 2007 model No power to engine or hydraulics
Sounds like a fuse has blown, look behind your dash panel.
Mar 15, 2017 • HP Boating
Have evinrude 115 v tec, tilt & trim has no power going up but has power going down, same at both the consul and botor.
try swopping the up solinoide for the down and see if problem switches around !!!! ?
Feb 23, 2015 • Boating
93 honda accord driver side electric windows repair''
CHECK FOR CORRODED WIRES AND SEE IF POWER GOING TO WINDOW REGULATORS, YOU ARE GOING TO NEED TO TAKE OFF THE DOOR TRIM TO SEE THEM, OTHER THAN THAT IT WILL BE ABOUT REPLACING THE REGULATORS.
7helpful
2000 Honda Odyssey rear wiper motor replacement
You are probably correct in thinking its the wiper motor. You can do this but you will need to remove all the interior trim from the rear hatch first. Get a trim clip removal tool at a parts store...it will work much better than just a flat blade screwdriver. You'll have to remove the trim panels starting in order from the top of the door, then the left rear window side trim, then right rear window side trim, then the grab handle, and finally the main rear hatch trim panel. Once inside, removing and replacing the rear wiper motor is easy. You'll start by lifting the cover on the wiper arm retention nut. Remove this nut to get the wiper arm off, then remove the nut under neath which is the motor shaft mounting nut. Now, back inside to remove the other 3 motor mounting bolts. Don't forget to disconnect the connector for the motor wires. Reverse steps to replace.
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
