Coffee plus 12 cup programmable coffee maker and hot water system. cbw-24 series
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
SOURCE: How does it make coffee?
You fill it to the line indicating how many cups of coffee you want to make. Then you add coffee to the brew basket, at least 1 full heaping teaspoon per cup. Put the basket on top of the stem and place the stem into the coffee maker. Put the lid on and plug it in. That's it. Don't plug it in without the lid, it's a percolator. It will squirt the water out the top of the stem and it flows down through the coffee grounds.
SOURCE: My Cuisinart 12 cup programmable coffee maker will
Hello jimmarsh,
You are right, there is a way to fix this. This is really a common problem with this unit that is fixable.
I recently had this similar problem. If you still have your machine try the following.
Your described problem may be one of two problems. Let's start with
the easier solution first. In the DCC 1200 there is a filter "stick or
column" in the left rear. Pull it out and remove the clogged carbon
filter(s) that are in there. Shine a light into the receptacle and
remove the debris in the bottom. It is likely that this is causing the
problem with you machine needing to be started on multiple times. See
if this solution works. If it does, you might run 8 cups of water and
4 cups of vinegar through to help decalcify the units plumbing. Do this
once or twice and then rinse with at least one pot run-through of
clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following:
unplug the unit and lay it on its back. You will need a #10 torx
driver (hardware store if you don't have one) to remove the bottom
cover plate. There are 4 torx screws holding it on. When removed, you
will find 2 orange hoses. Carefully attempt to remove the left hose
without splitting. I used an eyeglass screwdriver to loosen it up. If
it splits, just cut off the split and stretch it to reconnect when time
comes. As you look into the hose you will find a little black valve
inside as well a some gunk. Clean it all out with a fine wire as best
you can. Rinse well. Attempt to reconnect the hose back onto the
pipe. Slip the pipe clamp back into place. Replace the cover and
screws and you should be good to go again. This is not as daunting as
it may seem. You can do it. :o) Good luck! If this answer helps,
please leave positive feedback for me. Much appreciated. Regards,
NormanZ
SOURCE: cuisinart Coffee on Demand?12-Cup Programmable Coffee
Hello crystalmeikl,
This is a really common problem with the cuisinarts. I am most familiar
with the DCC-1200, but you may be able to solve the problem. The may be
an indication that something is plugged up. Open the top of
the unit and in one of the corners you should find a water filter stick or
column that is removable. Pull it out and open it up to clean out the
clogged up carbon filter in there. (You can later buy a new filter on
Amazon.) Clean out the debris from the bottom of the cavity. Replace
the stick into the cavity once cleaned. Now it's time to run through a
solution of 2 parts water and 1 part vinegar. Do this once or twice
with fresh solutions, then with a pot of fresh water. When the filter
stick is plugged up the sensor says its time to clean it or shuts the unit down, but most
people don't know about this fix. I hope this is helpful to you, crystalm. Positive feedback is appreciated. Good luck. NormanZ
SOURCE: hot water does not go through the individual cup
check to see if the outlet hole is plugged up and use a tooth pik to clean it out then try bo brew again..
