NOT from Outside.
If Possible empty pool now with a Controlled drain...
Peel back liner and clean area real good. Sand or steel wool to remove rust. Then Paint using one of those "Rubber" based leak sealing paints found in your local DIY warehouse store.
Then place a piece of Thin sheet metal against the wall after paint dried. Replace liner, coping strip, ridgidizing metal bar, and top rail.
Refill.
or if you're lucky...
Patch the liner. When all is dry, use 3 applications of Epoxy Putty like JB Weld. Place a small covering over the DRY area with the hole. If possible, force some into the hole.
Once dried and cured, place a 2nd patch, slightly larger over it, and then repeating a 3rd time, again slightly larger.
Not as good as First method, but may still work?
If left unattended...
The water pressure in the pool, will push the liner right thru that hole - like a hernia, and will burst thru releasing all your water and possibly collapsing the pool? This will be an "Uncontrolled" drain vs. the controlled drain above.
I guess you can choose which way you want to drain your pool?
Weld 8265S Original Steel Reinforced Epoxy Twin Pack 2 oz
Well, there's an option to solve different issues, when I want to fix or repair something, I look for video tutorials on YouTube, so there are answers to many questions with video instructions there and it's very convenient. Well, I have another problem, the pool cleaner is broken so I'm looking for a new one to replace it. I just found a great blog in which there are different home&garden tips and ideas, and there is the pool cleaner buying guide on this page. I hope I can find the best solution like what pool cleaner to choose. Any advice?
