Question about Samsung PPM50M5H On/off timer, 50 inches Wide Screen Plasma Monitor, Auto power offDigital Zoom, picture freeze, 0.81 x 0.81 Pixel Pitch, Black, DNIe, Burin-in Protection, PIP/PBP, Multiple Display Control, Mutli-layer anti-reflection filter, 3D comb filter,
The picture goes off after an hour but sound stays on
Haier LCD picture goes dark, sound only
hi, since your TV is under warranty,It is better to ask for a replacement a new one ..the problem is factory defect.
Apr 02, 2012 | Haier HL15R LCD TV
Pioneer elite pro-99/pro-119 60inch projection 10years old. Picture stays on for 1&1/2 hours and then goes blank. have sound.Problem?
and does this sound comes for that one hour or not??
and do you hear any kind of clicking noise when the unit shuts down??
this seems to be like a thermal heating problem of some components.
Aug 12, 2008 | Televison & Video
TV STAYS ON WITH SOUND AND PICTURE FOR ABOUT 20 SECONDS .THE SOUND AND PICTURE GOES OUT FOR APPROX. MINUTE ,THAN THE SOUND AND PICTURE RETURNS .THIS PROCESS HAPPENS OVER AND OVER
It is symptom of weak lamp that has been reached to end of its working hours life and need to be replaced to solve this problem.
Replace lamp in your tv, procedure is easy and would be written in your tv user manual.
Buy Sony original lamp for good picture in tv.
Thanks.
Nov 21, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Sound stays on, but no picture- goes black and stays that way.
This unit should still be under warranty and should be taken in for warranty service. Any attempt to access the interior will void the warranty. It is important that a complete description of the problem like you entered here be taken along when you bring the set in for service. This will insure that the servicer be able to reproduce the problem and resolve it.
From your description (and as a servicer), I would be looking for a component that is heat sensitive. These types of problems are fairly easy to locate and resolve.
Please take this in for warranty service and update this when you find out the details.
Thanks,
Dan
May 04, 2010 | JVC LT-26C31 26 in. LCD Television
Picture goes out - but has sound
i have had this problem on one of my tv s all i did was remove the back of the tv and re-solder all the joints around the tuner (thats where the arieal goes) they go with time because the joints there get so hot . hope this helps
puggy
Jul 07, 2009 | Televison & Video
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Picture goes out, sound stays on
I am not familar with that particular set, but this is what I would check (assuming you don't have a surround sound system hooked up to it as it would sound like a tuner problem otherwise). If you have external Audio/Video jacks with cables hooked up to the Direct TV box, move the video cable and see if you lose video when it is jiggled. If so, you either have a bad cable or connection/connector. When you say you have to turn the TV off for about 30 minutes, do you leave the directTV box on? If so, then the problem seems to be with the TV. Otherwise, maybe the direct TV box is at fault -- leave the TV on and turn off the cable box for a half hour and try it again. You have a few possibilities here, good luck.
Jan 20, 2007 | RCA 27R411T 27" TV
Samsung PPM50M5H On/off timer, 50 inches Wide Screen Plasma Monitor, Auto power offDigital Zoom, picture freeze, 0.81 x 0.81 Pixel Pitch, Black, DNIe, Burin-in Protection, PIP/PBP, Multiple Display Control, Mutli-layer anti-reflection filter, 3D comb filter, Logo
Top Samsung Car Audio & Video Experts
Marvin
Marvin
Vernon Taylor
Are you a Samsung Car Audio and Video Expert? Answer questions, earn points and help others
