2003 kia Sedona won't start no sound when I turn key not the starter had that checked and my battery goes dead had it towed home then when taken off tow truck it started next day won't start got new batterie won't start PLEASE HELP!!! Has kia alarm??
SOURCE: 2004 Kia Sedona wont start but i can hear starter.
if the starter is revving very slowly it is the battery, charge battery. if not, It can be three things happing. 1 no spark 2 no fuel 3 no crank signal or the car computer is bad- you will need to unplug one of the spark wires and remove the spark plug and put the spark plug in the spark plug wire boot, and touch the spark plug on any metal on the car and have some start the car. donot touch the spark plug itself and see if there is a spark. if spark is bright, then it is not spark plug and wires but if no or spark is not bright, check the spark plug wires by applying a little bit of water on the spark plug wire and take a 12v test light, connect the clap to ground and and have some one to crank the vehicle, touch allover the spark plug wires with the tip of the test light, if you see spark, replace the wires and change the plugs.. they are not good. if spark is present, check for fuel by removing any one of the spark plugs and see if it is wet. if wet fuel pump is ok but if not go look for the fuel pump fuse and relay. is fuse blown, replace, check the relay resistor with a volt meter. it should be around 40 to 80 ohm. if everything is good from this point check the fuel pump itself by disconnecting the connector to the pump and apply 12v and ground using jumper wires or some wires to the fuel pump if you donot hear the pump,replace pump. if you, the crank signal or computer may be the problem
SOURCE: 1999 Kia Sportage: Issue with car starting
You may need a starter. My 99 Kia would get me places and would refuse to start. Someone hit the starter with a wrench and it started right up. I had to hit the starter to get my Kia to start until I replaced it.
Hope this helps.
SOURCE: put in new battery in 2006 kia sedona but after
You may need a New alternator, An alternator is a device which charges the battery after you use it to start the motor, it also runs all the electrical components like headlights and air conditioner fans etc. Have this checked Take it to your closest auto mechanic.
SOURCE: 2003 Kia Sedona wont start.
is the car trying to turn over at all do you have lights what noise is it making i would say if other battery was dead could be alternator
